How Does Pressure Affect the Boiling Point of Water?
The discussion centers on the relationship between pressure and the boiling point of water, emphasizing the concept of phase transitions. The initial query involves the compression of gaseous water under external pressure and its transition to liquid state, followed by the effects of heating on internal pressure leading to boiling. Key points include the necessity for internal pressure to exceed external pressure for boiling to occur and the importance of understanding phase diagrams. The conversation highlights the need for clarity on the differences between gas, liquid, and solid states in relation to pressure and temperature.
  • Understanding of phase transitions (gas, liquid, solid)
  • Familiarity with pressure and temperature relationships
  • Basic knowledge of thermodynamics
  • Ability to interpret phase diagrams
  • Study phase transitions in detail, focusing on the water phase diagram
  • Learn about the Clausius-Clapeyron equation and its application to boiling points
  • Research the effects of temperature on phase changes in various substances
  • Explore thermodynamic principles related to energy flow during phase changes
Students of chemistry, physics enthusiasts, and anyone interested in understanding the principles of thermodynamics and phase transitions, particularly as they relate to water.
jay_me
Hi everyone,
I have been mulling over the relationship between pressure and boiling for some time, and I am still slightly confused. I shall attempt to provide an overview of my current understanding in the hope that I can get some corrections/clarification on my current conceptual understanding.
I shall start with the following: Imagine I have some fixed amount of water, say 1 mole, in the gaseous state. I apply an external pressure to this mole of water, and the gaseous water applies its own pressure on the sorroundings. It would seem to me that, if the external pressure is greater, then the gaseous water will be compressed. Let's say that the external pressure is greater. The gaseous water is compressed and begins to condense into the liquid state. As it is compressed, it exerts increasing pressure on the surroundings. Let's say that I can apply sufficient external pressure to force the water into a liquid state, but that the external pressure I can apply is limited. At some point, the pressure the water applies to the surrounding should equal the external pressure; at this point, the water ceases to be compressed. It seems to me that this would have to be the case: if the external pressure was greater, then the liquid water would continue to compress.
Okay, so the two are equal, the pressure that the water applies to its surroundings (I am going to call this internal pressure) is equal to the pressure from the surroundings (I am going to call this external pressure). Now I am going to heat the liquid water, increasing its thermal energy and increasing its internal pressure. It therefore begins to exceed the external pressure and expands. As its volume increases, its pressure decreases; if it again equals the external pressure, it will cease to expand. If it expands sufficiently, the pressure within the bulk of the liquid should drop enough for the liquid water to enter the gas phase. This is what boiling is.
Does this explanation in anyway make sense?
I have a sneaking suspicion it is wrong, but I am not sure how.
Thanks for any responses.
:welcome:
Your narrative is contradictory. You start with a gas, then later you assume it is a liquid. Also, you can't treat the pressure vs temperature nature of a gas to the pressure vs temperature nature of a liquid or a solid.
I think what you are trying to ask is about phase transitions gas/liquid/solid.
From https://en.wikipedia.org/wiki/Phase_transition
This wiki page may help. Read that first, then come back with questions about the parts you don't understand.
@jay_me
Your question doesn't include how the temperature affects things. From the above phase diagram, you can see that temperature / pressure combinations both affect what phase the water is in. Energy has to flow in or out of the water for a phase change. Read up what @anorlunda has suggested (and as many more sources as you can manage). It will all come clear but don't try to rely too much on making your own conclusions - that's a potentially wasteful way of learning.
  • · Replies 32 ·
10K
  • · Replies 31 ·
11K
  • · Replies 69 ·
  • · Replies 39 ·
  • · Replies 27 ·
