Pressure, energy density, and power of a fluid flow
The discussion centers on the relationship between pressure, energy density, and power in fluid flow. It establishes that static pressure can be viewed as energy density, but emphasizes that kinetic energy must also be considered when calculating power. The formula for power is confirmed as Power = Pressure x Volumetric Flow Rate (P x Q), while clarifying that volumetric flow rate inherently includes fluid velocity. The conversation critiques the HyperPhysics article for inaccuracies regarding gas pressure and the treatment of fluids.
  • Understanding of Bernoulli's equation in fluid dynamics
  • Familiarity with the concepts of pressure and energy density
  • Knowledge of kinetic energy in fluid mechanics
  • Basic principles of volumetric flow rate and its implications
  • Study the Bernoulli equation and its applications in fluid flow
  • Learn about the relationship between pressure and kinetic energy in fluids
  • Explore the concept of energy density in both gases and liquids
  • Investigate the implications of incompressibility in liquid dynamics
Engineers, physicists, and students studying fluid dynamics, particularly those interested in the interplay between pressure, energy, and flow characteristics in various fluid systems.
dan28029
I've read that you can view static pressure of a fluid as energy density, which makes sense to me. I've also seen that the power of a fluid flow can be calculated by multiplying the pressure by the volumetric flow rate. However, doesn't a flow also have kinetic energy? How can you calculate the power delivered by a fluid flow without incorporating the kinetic energy per unit volume? Why isn't Power= (P+ density*v^2/2)*Q
http://hyperphysics.phy-astr.gsu.edu/hbase/press.html
Thanks!
The hyperphysics article is wrong on two important things. First, it says
When you deal with the pressure of a liquid at rest, the medium is treated as a continuous distribution of matter. But when you deal with a gas pressure, it must be approached as an average pressure from molecular collisions with the walls.
This is not true, in normal conditions gases (air) are fluids and can be described by the same kind of continuous distribution of matter. Only when the gas gets very rare this breaks down and the ballistic description is necessary.
Pressure in a fluid can be seen to be a measure of energy per unit volume by means of the definition of work. This energy is related to other forms of fluid energy by the Bernoulli equation.
This is true only for ideal gas; the pressure P is proportional to kinetic energy of molecules per unit volume. In liquids, this is no longer true. The pressure is not proportional to total energy of liquid per unit volume.
This can be easily seen if we ask how much work need to be done to produce great pressure, says 10 bar, in water. Since the water is almost incompressible, the required work is very small. Hence the energy of pressurized water is almost the same as the energy under low pressure; the increase of pressure does not mean the energy increases as well. They are separate quantities.
Thanks!
Pressure x volumetric flow rate , P x Q = Power
doesn't the volumetric flow rate already incorporate the velocity of the fluid? ( you have to say yes )
Force x velocity = power
just divide pressure and Q by the area ( you should get Force x velocity )
just remember, Bernoulli is an energy balance from one point to another point of the fluid flow.
If the energy density is described as that per unit weight
then you have pressure energy + kinetic energy + gravitational potential energy = constant.
  • · Replies 35 ·
  • · Replies 48 ·
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 48 ·
