Pressure increase in a closed system
The discussion focuses on calculating the pressure increase in a closed system when liquid water is trapped in a rigid pipe due to a lapse in standard operating procedures (SOP). Scott, a refrigeration industry professional, seeks to quantify the pressure gain per degree of temperature increase. Chet provides a solution involving the volumetric strain of water, determined by its coefficient of thermal volume expansion, and the necessary pressure calculated using the bulk modulus of the fluid. This approach allows for a definitive calculation of pressure changes in a fully constrained liquid scenario.
  • Understanding of volumetric strain and its calculation
  • Knowledge of the coefficient of thermal volume expansion for water
  • Familiarity with the concept of bulk modulus in fluids
  • Basic principles of thermodynamics related to pressure and temperature
  • Research the coefficient of thermal volume expansion for water
  • Learn how to calculate volumetric strain in constrained fluids
  • Study the bulk modulus of various fluids, focusing on water
  • Explore real-world applications of pressure calculations in refrigeration systems
This discussion is beneficial for refrigeration engineers, mechanical engineers, and professionals involved in fluid dynamics or pressure systems who need to understand the implications of temperature changes in closed systems.
DarkF1ame
Hello All,
I work in the refrigeration industry, and I'm trying to put a hard number on a hypothetical situation. The situation is a lapse in SOP and liquid gets trapped in a line. For this hypothetical situation the line is 100% full. What would the increase in pressure be per degree?
I know that the density (g/cm3) goes down as temperature is increased. So with a fixed mass, the cm3 number must go up to lower the overall density, but since the scenario is 100% full, my brain tells me that energy is getting transmitted into the pipe walls as pressure since it can't physically expand any more. What I can't figure out is how to enumerate that pressure gain.
Any help would be greatly appreciated.
For this example, the trapped liquid in the pipe is water.
Thanks,
Scott
DarkF1ame said:
Hello All,
Thanks,
Scott
If the pipe is rigid so that it doesn't expand, then first you calculate how much the water would expand if it were not constrained (volumetric strain). This is determined by its coefficient of thermal volume expansion. Then you calculate how much pressure would be required to remove that same amount of volumetric strain. This would be determined by the bulk modulus of the fluid.
Chet
  • · Replies 48 ·
15K
49K
