Pressure losses in electric air heater
The discussion centers on the pressure loss of 3kPa in an electric air heater and its implications for outlet velocity and mass flow rate. The user seeks clarification on whether this pressure loss is static, dynamic, or a combination of both, and how it affects calculations using Bernoulli's equation. They provide specific values for static pressures and velocities, ultimately calculating an outlet velocity of 71m/s, which seems excessively high. The conversation highlights that while the volumetric flow rate changes due to air expansion when heated, the mass flow rate remains constant. The user is looking for insights into potential errors in their calculations and the overall impact of pressure loss on system performance.
kyle pender
I have an electric air heater with a pressure loss of 3kPa (according to manufacturer at the flow rate and temperature I will be using). Air is supplied to the heater using a centrifugal fan with a static pressure of 8.7kPa (gauge) and a flow rate of 88m3/hr, giving a dynamic pressure of around 95Pa.
My question is; will this loss of 3kPa be static, dynamic or a bit of both? I would like to calculate the outlet velocity after passing through the heater (using bernoulli equation) and I having difficulty without knowing what pressure to deduct the 3kPa from.
It's the static pressure.
Likes russ_watters
How would this effect the mass flow rate leaving the heater? I was under the impression the 3kPa loss would result in some loss in mass flow (i.e. cannot assume mass flow rate across heater is constant). I have a means of measuring the heater inlet velocity but not outlet (especially when it is at operating temperature) so would like get at at least a general idea of the outlet velocity.
Ignoring the heating effects, i.e. running flow through heater when off:
Pstatic in =108.7kPa, Pstatic out=105.7kPa therefore Pstatic in-Pstatic out=3kPa
rho in = rho out =1.225kg/m3 (assumption made for simplicity)
velocity in = 12m/s
Using Bernoulli eqn.
velocity out=SQRT(velocity in^2+2(Pstatic in-Pstatic out)/rho)
After subbing in values I get, velocity out=71m/s...This seems really high, can you see any error in this logic?
This value will also only increase when I add the effect of the temperature rise on the air density.
Thanks
The volumetric flow rate across a heater changes because the air expands when heated. The mass flow rate stays the same because there is nowhere else for the mass to go.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
