Can Human Forearm Bones Withstand the Stress of a High-Speed Car Crash?
frenchy7322
states of matter problem, me = :confused:
Total cross-sectional area of a load-bearing calcified portion of 2 forearm bones is approx 2.4cm squared. During a car crash, the forearm is slammed against the dashboard. the arm comes to frest from intiial speed of 80 km/h in 5.0 ms. If arm has effective mass of 3.0 kg and bone material can withstand a max compressional stress of 16x10^7 Pa, is arm likely to withstand crash?
Not sure on which equation to use due to not really getting the conceptual side of the question, please help!
The compressional stress is a pressure, which is a force per area. You have the cross-sectional area of the bones, so you need the force applied. You know the mass upon which the force is applied, so you need the acceleration. The average acceleration can be found from the information that the bones are brought to rest from an initial speed of 80 km/hr in 0.005 seconds. (You only care about the magnitude of this acceleration; it doesn't matter that the acceleration is negative.) Be careful about your units: everything should be converted to SI, since you want the pressure in Pascals.
How does the average pressure to which the bone is subjected during this deceleration compare to 1.6·10^8 Pa?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
