erobz
- 1,864
I was just thinking there must be some base model, where the heat input establishes the thermal gradient in the water column, and a free convection within a column is creating the flow. Warm fluid is less dense and rises, cold fluid sinks. I can see this happening vertically, but it's harder to swallow that a bulk flow is established in a loop as if there were a pump circulating the flow. What is the base model for this is what I'm asking...its probably going to be complicated even with simplifying assumptions; whatever they may be.gmax137 said:The analyses I have been involved in studied the natural circulation flow in a system with a heat source down low and a heat sink up high. A closed loop with pumps installed but not running.
We did this numerically with a computer program that divides the system up into ~50 "nodes" and solves mass, energy, and momentum conservation. This allows for temperature & pressure-varying physical properties (eg, density), and flow-dependent resistance, etc. as well as varying the heat input and removal rates.
It can be done by hand but you have to make simplifying assumptions.
