How to Calculate Work Done from a PV Diagram?
KJ22
Look at the PV diagram of a system above. The units for P and V are atmospheric pressure atm and liter L. Process A to B and B to C are straight lines on it.
How much is the work done by the system from A to C in J?
https://tycho-s.physics.wisc.edu/cgi/courses/shell/common/showme.pl?courses/phys103/fall08/homework/12/pv/pv.gif
HELP: In general, the work done in an expansion from some initial state to some final state is the area under the curve on a PV diagram. So determine the area under the ABC-curve.
HELP: Each square on the diagram has an area of: 1.5 atm * 1 L = 1.5 atm L = 152 J. Estimate the numbers of squares below the ABC-curve and multiply that number by 152 J. Good luck
Wab= pressure x change in volume= 303975 Pa(.004meters cubed)= 1215.9
Wbc= pressure x change in volume= 607950 Pa(.006 meters cubed)= 3647.7
W= Wab +Wbc
but this is not correct. Can anyone help me?
I did what you said, i.e. counted the squares under the curve and multiplied that number by 152, but I do not get the same answer as you. Try dividing the area into two rectangles and two triangles and calculate those four areas separately. Use the formula for the area of a triangle rather than guessing how many squares make up the triangle. Hope that helps.
thanks! that worked.
I got the Area of the triangles to be 4 and 3 and the area of the rectangles to be 8 and 18. multiplied by 152 and got an answer of 5020 J.
thanks for your help!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
