Finding the Primitive Function for y'(x)=xcos(x2) | Homework Help and Equations
  • Thread starter Thread starter jakobs
    Primitive
To find the primitive function for y'(x) = xcos(x²), the integral can be approached by substituting u = x², which leads to du = 2xdx. This allows the integral to be simplified to (1/2)∫sin(u)du, resulting in y(x) = (1/2)sin(x²). The discussion highlights that while formal methods are useful, they may not be necessary for straightforward problems. Ultimately, the correct primitive function is confirmed to be y(x) = (1/2)sin(x²).
jakobs
I have y'(x)= xcos(x2)
How do I get the primitive function for this?
I know that f'(x)=2xcos(x2) is f(x)=sin(x2)
How will removing that 2 in front of xcos affect the primitive function?
y(x)=1/2f(x)
A more "formal" way to do this would be to let u= x^2 so that du= 2xdx or (1/2)du= xdx. Then \int x sin(x^2)dx becomes (1/2)\int sin(u)du. Alternatively, write \int x sin(x^2)dx as (1/2)(2)\int x sin(x^2)dx= (1/2)\int sin(x^2)(2x)dx
Note that you can only move constants into and out of the integral like that. If that first "x" were not there, you could not do the integral.
conquest said:
y(x)=1/2f(x)
So, the answer should be f(x)=1/2 sin(x) ?
HallsofIvy said:
A more "formal" way to do this would be to let u= x^2 so that du= 2xdx or (1/2)du= xdx. Then \int x sin(x^2)dx becomes (1/2)\int sin(u)du[/tex]. Alternatively, write \int x sin(x^2)dx as (1/2)(2)\int x sin(x^2)dx= (1/2)\int sin(x^2)(2x)dx<br />
<br /> <br /> I&#039;m not completely understand everything you wrote there, and I feel a bit stupid now.
@jakobs
well you actually put f(x)=sin(x²). So I meant y(x)= 1/2 sin(x²). Then indeed y'(x)=xcos(x²).
@Halls of Ivy
Agreed this would be the 'follow the recepy' way of doing it, but with a problem this straightforward it really isn't necessary.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
