B Private solution to a polynomial differential equation
Karol
The polynomial equation and it's private solution:
$$(1)~~ay''+by'+cy=f(x)=kx^n,~~y=A_0x^n+A_1x^{n-1}+...+A$$
If i, for example, take ##f(x)=kx^3## i get, after substituting into (1), an expression like ##Ax^3+Bx^2+Cx+D## , but that doesn't equal ##kx^3##
Please show your working.
The general solution of <br /> ay&#039;&#039; + by&#039; + cy = ky is Ae^{r_1x} + Be^{r_2x} where r_1 \neq r_2 are the roots of ar^2 + br + (c - k) = 0. If the roots are equal then the general solution is instead Ae^{r_1x} + Bxe^{r_1x}.
You can therefore obtain y(x) = x as a solution by taking b = 0 and k = c.
But that is that the DE under consideration in post #1?
Compare:
##ay'' + by' + cy = ky## with
##ay'' + by' + cy = kx^3## ...
$$y=A_0x^3+A_1x^2+A_2x+A,~~y'=3A_0x^2+2A_1x+A_2,~~y''=6A_0x+2A_1$$
$$ay''+by'+cy=6aA_0x+2aA_1+3bA_0x_2+6bA_1x+bA_2+cA_1x^2+cA_2x+cA=(cA_0)x^3+(3bA_0+cA_1)x^2+(6aA_0+6bA_1+cA_2)x+(2aA_1+bA_2+cA)$$
Is there a phrase about a polynomial with many members to equal only one with the highest power?
OK ... is that as far as you got?
You need an ##=kx^3## in there someplace?
Check the algebra on the others too ... then solve for the unknown coefficients.
(Probably easier to write the coefficients as A,B,C,D like you did in post #1)
Simon Bridge said:
You need an =##kx^3## in there someplace?
$$(cA_0)x^3+(3bA_0+cA_1)x^2+(6aA_0+6bA_1+cA_2)x+(2aA_1+bA_2+cA)=kx^3$$
I
$$\left\{ \begin{array}{l} cA_0=k \\ 3bA_0+cA_1=0 \\ 6aA_0+6bA_1+cA_2=0 \\ 2aA_1+bA_2+cA=0 \end{array}\right.$$
$$\rightarrow~~A_0=\frac{k}{c},~~A_1=-\frac{3bk}{c^2},~~A_2=\left( \frac{3b_2c-a}{c^3} \right)6k,~~A=\frac{6abk}{c^3}-\left( \frac{3b_2c-a}{c^3} \right)6bk$$
Is that what you meant?
That's the idea... test for a=b=c=d=k=1 (say).
Thank you pasmith and Simon
