MHB Probability Challenge: Jason's 2010 Coin Flips
Jason's coin has a probability of $\frac{2}{3}$ to match the previous flip and $\frac{1}{3}$ to show the opposite side. After flipping the coin once and getting heads, he flips it 2010 more times. The probability that the last flip is heads can be calculated using a Markov chain approach with the transition matrix provided. The final probability is expressed as $P = \frac{1 + 3^{-2010}}{2}$, which is very close to $\frac{1}{2}$.
anemone
MHB
POTW Director
Jason has a coin which will come up the same as the last flip $\dfrac{2}{3}$ of the time and the other side $\dfrac{1}{3}$ of the time. He flips it and it comes up heads. He then flips it 2010 more times. What is the probability that the last flip is heads?
Mathematics news on Phys.org
[sp]It's a simple Markov chain problem and the transition matrix is...
$\displaystyle A = \left | \begin{matrix} \frac{2}{3} & \frac{1}{3} \\ \frac{1}{3} & \frac{2}{3} \end{matrix} \right |\ (1) $
The solution is the term of first line and first column of $ A^{n}$ for n=2010. This term is the solution of the difference equation...
$\displaystyle a_{n+1} = \frac{a_{n}}{3} + \frac{1}{3}\ a_{1}= \frac{2}{3}\ (2)$
... which is...
$\displaystyle a_{n} = \frac {1 + 3^{- n}}{2}\ (3)$
The requested value is therefore $P = \frac{1 + 3^{- 2010}}{2}$, very close to $\frac{1}{2}$ of course (Wink)...[/sp]
Kind regards
$\chi$ $\sigma$
... which is...
Kind regards
$\chi$ $\sigma$
Well done, chisigma, well done!:cool:
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
