MHB Probability of Reaching Room Q in n Seconds
The discussion focuses on calculating the probability of a ball reaching room Q from room P in a network of rooms after n seconds, with the condition that the ball moves randomly to adjacent rooms. It is established that if n is odd, the probability is zero since both rooms P and Q are unshaded. For even n, the probability is derived using transition probabilities, concluding that the probability of reaching Q after 2k moves is given by the formula (2^(n/2) - 1) / (3 * 2^(n/2)). The conversation highlights the complexity of the problem, with participants sharing their approaches to finding the solution. Ultimately, the correct probability formula is confirmed, showcasing the mathematical reasoning involved.
jacobi1
The image shows a network of rooms. A ball starts in room P. If the ball moves from one room to another adjacent one every second (assume no time is spent between the rooms) and it randomly chooses a room to go to, find the probability that it reaches room Q after n seconds. A room is adjacent to another room if and only if they share a side-for example, P is adjacent to three rooms.
Mathematics news on Phys.org
To clarify, do you want the probability that the ball reaches Q for the first time after n seconds, or do you include the possibility that it may also have visited Q previously?
I include the probability that it may have visited Q previously.
[sp]
First, notice that each move of the ball takes it either from a shaded room to an unshaded room, or from an unshaded room to a shaded room. Since rooms P and Q are both unshaded, it is impossible for the ball to go from P to Q in an odd number of moves. So if $n$ is odd, the probability is $0$.
So assume that $n$ is even, and think about the transition probabilities after two moves. The only way to get from P to Q in two moves is to go via the shaded room between them. The probability of going to this shaded room from P is $1/3$, and the probability of then going from the shaded room to Q is $1/2$. So the probability of going from P to Q in two moves is $1/6$. By symmetry, the probability of going from P to R in two moves is also $1/6$. The probability of going from P back to P in two moves is therefore $2/3$ (since the probabilities must add up to $1$). Thus the matrix $T$ giving the transition probabilities between P, Q and R (in two moves) is $$T = \frac16\begin{bmatrix} 4&1&1 \\ 1&4&1 \\ 1&1&4 \end{bmatrix}.$$ Let $I$ denote the $3\times3$ identity matrix, and let $E$ be the idempotent matrix $$E = \frac13\begin{bmatrix} 1&1&1 \\ 1&1&1 \\ 1&1&1 \end{bmatrix}.$$ Then $T = \frac16(3I+3E) = \frac12(I+E)$, and $$T^k = \frac1{2^k}(I+E)^k = \frac1{2^k}\Bigl(I + {k\choose1}E + {k\choose2}E + \ldots + {k\choose k}E \Bigr) = \frac1{2^k}\bigl((2^k-1)E + I\bigr)$$ (using the fact that $E$ is idempotent). The $(2,1)$-element of this matrix is $\dfrac{2^k-1}{3\cdot 2^k}$. Therefore the probability of the ball being in room Q after an even number $n\;(=2k)$ of moves is $\dfrac{2^{n/2}-1}{3\cdot 2^{n/2}}$.[/sp]
Congratulations, Opalg, your answer is correct. And much faster than mine, too.:)
I did this the hard way. As in, the long, stupid way.
I turned the network of rooms into a graph as in the image by considering the rooms as vertices and numbering them 1 through 9. Room P is vertex number 2 and Q is number 4. Then I made a Markov transition matrix representing the probabilities of going from one room to another.
M=
\left[ {\begin{array}{ccccccccc}
0 & 1 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
\frac{1}{3} & 0 & \frac{1}{3} & 0 & 0 & 0 & 0 & 0 & \frac{1}{3} \\
0 & \frac{1}{2} & 0 & \frac{1}{2} & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & \frac{1}{3} & 0 & \frac{1}{3} & \frac{1}{3} & 0 & 0 & 0 \\
0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & \frac{1}{2} & 0 & 0 & \frac{1}{2} & 0 & 0 \\
0 & 0 & 0 & 0 & 0 & \frac{1}{3} & 0 & \frac{1}{3} & \frac{1}{3} \\
0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 \\
0 & \frac{1}{2} & 0 & 0 & 0 & 0 & \frac{1}{2} & 0 & 0 \\
\end{array} } \right]
(Crying)
Then I diagonalized it (with my handy link, because I refused to do it by hand), took it to the nth power, and I got
M^n = PD^n P^{-1} =
1 & 0 & 1 & 0 & 1 & 1 & 1 & 0 & 0 \\
-\frac{1}{\sqrt 2} & 0 & \frac{1}{\sqrt 2} & 0 & -1 & 1 & 0 & 0 & 0 \\
0 & 1 & 0 & 1 & 1 & 1 & 0 & 1 & 0 \\
\frac{1}{\sqrt 2} & -\sqrt 2 & -\frac{1}{\sqrt 2} & \sqrt{2} & -1 & 1 & 0 & 0 & 0 \\
-1 & 2 & -1 & 2 & 1 & 1 & 0 & 0 & 1 \\
-\frac{1}{2} & 0 & -\frac{1}{2} & 0 & 1 & 1 & 0 & -1 & -1 \\
0 & -2 & 0 & -2 & 1 & 1 & 1 & 2 & 1 \\
0 & \sqrt 2 & 0 & -\sqrt 2 & -1 & 1 & 0 & 0 & 0 \\
\frac{1}{2} & -1 & \frac{1}{2} & -1 & 1 & 1 & -1 & -1 & 0 \\
\end{array} } \right] \times
\left (-\frac{1}{\sqrt 2}\right )^n & 0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
0 & \left (-\frac{1}{\sqrt 2} \right )^n & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & \left (\frac{1}{\sqrt 2} \right )^n & 0 & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & \left (\frac{1}{\sqrt 2} \right )^n & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 & (-1)^n & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
\frac{2}{9} & -\frac{\sqrt 2}{3} & \frac{1}{9} & \frac{\sqrt 2}{6} & -\frac{1}{9} & -\frac{2}{9} & -\frac{1}{9} & \frac{\sqrt 2}{6} & \frac{1}{9} \\
\frac{1}{18} & -\frac{\sqrt 2}{12} & \frac{1}{9} & -\frac{\sqrt 2}{12} & \frac{1}{18} & -\frac{1}{18} & -\frac{1}{9} & \frac{\sqrt 2}{6} & -\frac{1}{18} \\
\frac{2}{9} & \frac{\sqrt 2}{3} & \frac{1}{9} & -\frac{\sqrt 2}{6} & -\frac{1}{9} & -\frac{2}{9} & -\frac{1}{9} & -\frac{\sqrt 2}{6} & \frac{1}{9} \\
\frac{1}{18} & \frac{\sqrt 2}{12} & \frac{1}{9} & \frac{\sqrt 2}{12} & \frac{1}{18} & -\frac{1}{18} & -\frac{1}{9} & -\frac{\sqrt 2}{6} & -\frac{1}{18} \\
\frac{1}{18} & -\frac{1}{6} & \frac{1}{9} & -\frac{1}{6} & -\frac{1}{18} & \frac{1}{9} & \frac{1}{18} & -\frac{1}{6} & \frac{1}{9} \\
\frac{1}{18} & \frac{1}{6} & \frac{1}{9} & \frac{1}{6} & \frac{1}{18} & \frac{1}{9} & \frac{1}{18} & \frac{1}{6} & \frac{1}{9} \\
\frac{4}{9} & 0 & -\frac{4}{9} & 0 & \frac{1}{9} & \frac{2}{9} & \frac{1}{9} & 0 & -\frac{4}{9} \\
-\frac{2}{9} & 0 & \frac{5}{9} & 0 & -\frac{2}{9} & -\frac{1}{9} & \frac{1}{9} & 0 & -\frac{1}{9} \\
\frac{1}{9} & 0 & -\frac{4}{9} & 0 & \frac{4}{9} & -\frac{4}{9} & \frac{1}{9} & 0 & \frac{2}{9} \\
We only want the $ (2,1) $ entry of the resulting matrix, so we only need the diagonal matrix and the second row and fourth column of the $P$ and $ P^{-1} $ matrices, respectively, to find the final matrix (See? I'm stupid-I figured this out only after I multiplied every single entry of the matrices-but I won't show that here). Multiplying, we get
$$ P_{2 \to 4} = \frac{\left ( 1-2^{-n/2} \right ) \Bigl ( (-1)^{n} +1 \Bigr )}{6}, $$
which works for any n, even or odd (it is 0 for odd n, as is clearly seen).
Confession: I also started by writing down a $9\times9$ matrix. But then I thought: that looks impossibly hard, there must be an easier way. (Headbang) (Emo)
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
