Probability density function and eulers constant
In summary, the conversation discusses a probability density function with variables D, E, A, B, and C. The question is raised about how to solve for eABC/2, which is a 5x1 matrix divided by 2. There is also discussion about the validity of matrix multiplication and the dimensions of matrices when multiplied together.
mikedamike
28
Hi,
I have a probability density function defined by
1 / D x E . eABC/2
D is a single number
E is a determinant of a matrix
. is the dot product between the two sides of the function
e I am pretty sure is meant to be eulers constant
A is a 5x1 vector
B is a 5 x 5 matrix
C is a 5x1 vector
To my understanding eulers constant can only be raised to the power of a single number
My question is that how can the second half of the equation be solved if i require eABC/2 (which is effectivly a 5x1 matrix / 2)?
Can anyone help me with this ?
Thanks in advance
Regards
Mike
Your multiplication ABC makes no sense. If A is a 5x1-matrix and if BC is a 5x1 matrix, then there is no way to multiply those. Unless you're looking at some sort of dot-product.
sorry ill make this more clear
A - This is a 5x1 matrix ( where A is actually the transpose of c)
B - this is a 5x5 matrix
c - this is a 5x1 matrix
This would mean axb = ab (5x1 )
ab X c = abc(5x1)
You can't multiply a 5x1 matrix and a 5x5 matrix.
Do you mean that A is the transpose of C? That way, A would be a 1x5 matrix! (which would make sense)
am i using the right convention ?
using MY description i have used [rows] x [columns]
BTW i do mean transpose ...sorry!
As I stated in the other forum I interpret ABC to mean A.(BC).
Sorry you are correct
it is
1x5 x 5x5 x 5x1
= 5x1
However this still mens i have a 5x1 /2
Also matrix exponential can only be done on square matrix ?
No. A 1x5 times a 5x5 times a 5x1 will yield a 1x1 matrix.
Side question : 1x5 times 5x5 matrix will be 1x5 matrix right ? Then 1x5 times 5x1 matrix can yield 1x1 because for a matrix to multiply , columns of first matrix must be equal to rows of second matrix , i.e. r2=c1.
Am I correct ?
@Mikedamike
ab X c = abc(5x1)
ab will be 1x5 matrix and not 5x1. You cannot multiply 5x1 times 5x1 because for two matrices to multiply , rows of second matrix must be equal to columns of first matrix but 1 is not equal to 5.
Am I correct ?
Yes, that is correct.
FAQ: Probability density function and eulers constant
1. What is a probability density function (PDF)?
A probability density function is a mathematical function that describes the likelihood of a continuous random variable taking on a specific value. It is used to represent the distribution of a random variable and can help determine the probability of different outcomes.
2. How is a PDF different from a probability mass function (PMF)?
A PDF is used for continuous random variables, while a PMF is used for discrete random variables. This means that a PDF can take on any value within a range, while a PMF only assigns probabilities to specific outcomes.
3. What is Euler's constant (e) and how is it related to probability?
Euler's constant, denoted by the letter "e", is a mathematical constant that is approximately equal to 2.71828. It is often used in probability calculations, particularly in the context of exponential growth and decay.
4. How is the area under a PDF curve related to probability?
The area under a PDF curve represents the probability of a random variable falling within a certain range of values. This area is always equal to 1, as the total probability of all possible outcomes must add up to 1.
5. Can a PDF be used to determine the probability of a specific outcome?
No, a PDF only provides the relative likelihood of different outcomes. To determine the probability of a specific outcome, you would need to calculate the area under the curve for a specific range of values.
