Probability Distribution of Random Variable X from a Double Dice Roll Experiment
  • Thread starter Thread starter ampakine
    Dice Pdf Roll
ampakine
The question is "An experiment in which a dice is tossed twice. Let X be the random variable defined by recording the higher of the 2 values obtained in the experiment. Determine the probability distribution of X."
I know that the range of this distribution is {1,2,3,4,5,6}. For P(X=1) both rolls will have to land on 1 so the probability is 1/36. As for P(X=2) I assumed that 1 dice has to land on 2 so that has a 1/6 probability and the other can land on either 1 or 2 so that's a 2/6 probability. Multiplying them together I get 2/36 but according to the answer I have for this question that's wrong. Heres the real answer:
http://imageshack.us/m/535/4747/distk.png
What am I doing wrong?
hi ampakine! :smile:
ampakine said:
As for P(X=2) I assumed that 1 dice has to land on 2 so that has a 1/6 probability and the other can land on either 1 or 2 so that's a 2/6 probability. Multiplying them together I get 2/36 …
no, because your method assumes that the first number is higher (if they're not equal)
either number can be higher
in other words: you've counted (2,1) and (2,2) but not (1,2) :wink:
Ah right, that explains it. Thanks a lot!
An easier way to derive the probability of maximums (and works with both discrete and cts distributions) is to first find the cdf:
P[max(X,Y)<=x] = P[X<=x,Y<=x] = P[X<=x]^2
then take the differences or derivatives to get the pmf or pdf.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
