Probability of Drunks Meeting After N Steps
  • Thread starter Thread starter Philowns
    Probability
Philowns
Here's one of the question to my problem set:
Two drunks start out together at the origin, each having equal probability of making a step to the left or right along the x-axis. Find the probability that they will meet after N-steps. It is to be understood that the men make their steps simultaneously. (It may be helpful to consider their relative motion.)
I don't know much about the related equation because we have no reference for this particular subject.
I'm not sure why you would need a specific book or equation. Just "reason" it out. If the two people, let's call them "A" and "B", where A is to the right of B, are distance x apart at time t, then there are four equally likely things that can happen:
A and B both move to the right- the distance between them does not change- it is still x.
A and B both move to the left- the distance between them does not change.
A moves to the right and B moves to the left- the distance between them increases, it is x+2.
A moves to the left and B moves to the right- the distance between them decreases, it is x- 2.
You should be able to find the probabililty distribution for x and so find the probability that it is, at some future time, 0.
The reason I need a textbook for probability (physics) because there are a lot harder questions than this. But anyway thanks for the reply. I'll start working on it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
