Probability of Measuring ##L_x = 0## for a Given ##\psi##
  • Thread starter Thread starter t0pquark
    Measurement
The discussion revolves around calculating the probability of measuring the angular momentum operator ##L_x## to be zero for a given state vector ##\psi## in quantum mechanics. The context involves understanding eigenvalues and eigenvectors associated with the operator ##L_x## and the transformation between different bases in a 3D Hilbert space.
  • Participants discuss the calculation of the probability using the inner product of the state vector with the eigenvector corresponding to the eigenvalue zero. There is a focus on transforming the state from one basis to another and determining the relevant components for the measurement.
Some participants have provided guidance on how to approach the problem, emphasizing the need to find the zeroth component in the x-basis without fully transforming the state. There is an acknowledgment of the calculations being performed, but no consensus has been reached on the final probability value.
Participants note the importance of expressing the state in the correct basis and the implications of linear algebra in determining the components of the vector. There is a mention of the original poster's uncertainty about the next steps in the calculation.
t0pquark
Compute the probability that a measurement of ##L_x## will give zero for an angular momentum particle (1) with ##\vert \psi \rangle = \begin{bmatrix} \frac{2}{3} \\ \frac{1}{3} \\
\frac{-2}{3} \end{bmatrix} ##.
In a 3D Hilbert space, for spin 1, ##L_x = \frac{\hbar}{2} \begin{bmatrix} 0 & 1 & 0 \\ 1 & 0 & 1\\ 0 & 1 & 0 \end{bmatrix}##.
The probability that a measurement of ##L_x## will give zero for a given ##\psi## should be ##\vert \langle L_x = 0 \vert \psi \rangle \vert ^2##, I think.
I found the eigenvalues of ##L_x## to be ##\lambda = -1, 0, 1##. Since it asks for the probability that the measurement will give zero, I think I should be looking at the eigenvector that corresponds to zero, which is ##\begin{bmatrix} \frac{1}{\sqrt 2} \\ 0 \\ \frac{-1}{\sqrt 2} \end{bmatrix} ##.
I am not sure where to go from here?
Simply calculate ##| \langle L_x = 0 | \psi \rangle |^2## in vector form.
t0pquark said:
Homework Statement: Compute the probability that a measurement of ##L_x## will give zero for an angular momentum particle (1) with ##\vert \psi \rangle = \begin{bmatrix} \frac{2}{3} \\ \frac{1}{3} \\
Homework Equations: In a 3D Hilbert space, for spin 1, ##L_x = \frac{\hbar}{2} \begin{bmatrix} 0 & 1 & 0 \\ 1 & 0 & 1\\ 0 & 1 & 0 \end{bmatrix}##.
You need to think about what you are doing. You have a state expressed in one basis ( the z-basis). And you really want that state expressed in another basis (the x-basis).
So, you could do all of the work to transform your state to the x-basis and then you could simply read off the probabilities of getting ##-1, 0, 1## for a measurement of ##L_x##: just take the modulus squared of each component.
But, you are only asked for the probability of getting ##L_x = 0##. So, you only need the zeroth component in the x-basis. So, you don't have to do all the work. You only need to find one component.
Now, if you think about linear algebra, the components of any vector ##\psi## in any basis are given by ##\langle b_n | \psi \rangle##, where ##b_n## is nth basis vector.
In this case, you want the zeroth component of ##\psi## in the x-basis. As you have calculated the zeroth x-basis vector, you can just take the inner product of this with ##\psi##. The probability, as above, is the modulus squared of this component.
That explanation helps!
So then I have ##( \begin{bmatrix} \frac{1}{ \sqrt 2} \\ 0 \\ \frac{-1}{ \sqrt 2} \end{bmatrix} \cdot \begin{bmatrix} \frac{2}{3} \\ \frac{1}{3} \\ \frac{-2}{3} \end{bmatrix} )^2 = (\frac{2}{3 \sqrt 2} + \frac{2}{3 \sqrt 2})^2 = \frac{8}{9}##, right?
The left vector should be a row vector, but otherwise it is correct.
