Solving a Probability Problem with Bayes Theorem
  • Thread starter Thread starter ENgez
    Probability
To find the probability that the last ball drawn is red given that the first ball drawn is not white, Bayes' theorem and conditional probability can be applied. The problem involves calculating outcomes based on the remaining balls after the first draw. The initial setup includes 5 red, 5 black, and 5 white balls, leading to a complex probability tree. Simplifying the calculations and focusing on the relevant events can help in solving the problem. This approach will clarify the relationships between the events and lead to the desired probability.
ENgez
you have a sack with 5 red balls, 5 black balls and 5 white balls. you take them out one at a time without returning until the sack is empty. what is the probability the last ball you took out is red given that the first ball taken out is not white.
it should be solvable using the bayes theorom, the definition of conditioned probabilty, and the complete probability formula.
i tried playing around with different events and using the formulas above but no luck... the main problem is that the probability tree is huge. i was hoping i can get a push in the right direction.
thanks.
Hi ENgez! :smile:
You have a sack with 5 red balls, 4 black balls and 5 white balls. You take them out one at a time without returning until the sack is empty. what is the probability the last ball you took out is red? :wink:
