How Likely Is More Than Two Successes in Six Trials with 10% Success Rate?
  • Thread starter Thread starter nachelle
    Probability Stats
The discussion focuses on calculating the probability of achieving more than two successes in six trials, with a success rate of 10%. The formula P(x > 2) = 1 - P(x ≤ 2) is highlighted as the method to determine this probability. Participants emphasize the importance of understanding the problem and not relying solely on others for step-by-step solutions. There is a reminder to avoid posting repetitive questions in the forum. Overall, the conversation stresses the need for independent problem-solving skills in probability calculations.
nachelle
given trails n = 6, success probability p = 0.1
radou said:
P(x > 2) = 1 - P(x \leq 2)
P(x \leq 2) = \left( \begin{array}{c} 8 \\ 0 \end{array} \right) 0.3^0 (1-0.3)^{8-0} + \cdots (sum until x = 2, including that case)
help
First, do not post same questions. Second, if you expect someone to solve the whole problem step by step (i.e. number by number), then you might be in the wrong forum. Third, without using your head, you won't solve any problem. Fourth, I'm not being rude.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
