Problem in identifying terminals of a capacitor of a fan
The discussion centers on testing an old fan capacitor to determine if it is functioning or faulty. Participants clarify that fan capacitors, typically metalized polypropylene types, are non-polarized, meaning terminal polarity is not a concern when testing. They advise using a multimeter to check for shorts and to verify the capacitor can hold a charge, suggesting a safe discharge method using a resistor. Additionally, they explain how to interpret multimeter readings, emphasizing that a good capacitor will show high resistance and should read "open" between leads and the case. Overall, the conversation provides practical guidance for testing and verifying the condition of the capacitor.
Wrichik Basu
Insights Author
I have a capacitor from a fan. The electrician says it's dead, but I think he is lying. I want to test it with a multimeter. But I can't identify which terminal is positive or negative as it's old and from local company.
A poor video of the capacitor is below:
A few pics from the video:
A sign on the bottom: company logo or identifier?
I came to kmow from a site that a fan capacitor used for starting the motor is unpolarised. Is that correct? If so, then I don't have to think of positive or negative terminals while testing, right?
If not, please help in identification.
Note the sign it has at its bottom: is that a company logo or an identifier?
I want to give the capacitor a death certificate, and I don't need to calculate the capacitance. I only want to see if it's OK. The electrician has charged quite a lot, and I want to see if he was telling the truth.
N.B.: The video quality might not be very good. It has no sound except background noise. I used it to show the capacitor from all sides.
Pics are from video which I uploaded, so the play and pause buttons have also come in the screenshot.
That appears to be a metalized polypropylene capacitor. They do not have a polarity as far as capacitor operation is concerned. They will often be marked as to which terminal is connected to the outer metal layer.
Also motor capacitors must be non-polarized in general.
BoB
Likes jim hardy and Wrichik Basu
BoB
So, when I test it with a multimeter, i don't have to look out for polarity, right? So the multimeter probes can be used on either terminal?
BoB
Also, can I discharge it with a 1k ohm 1/4 watt resistor that I have?
Yes. Also check for short to the case from both terminals.
Start with 10k or 20k. The total energy is low but you will get a surge. You can use the 1k one but if the voltage is at the maximum from a 220V line you may fry the resistor. If you use the 1k check that the voltage on the capacitor is low before proceeding. After your voltage is very low wrap a bare wire around the leads for a few minutes. This will help insure that any dielectric absorption is also discharged.
BoB
Likes Wrichik Basu
Could not understand what you meant.
The capacitor is already detached, and the electrician has fixed a new one. Then can I use the resistor I mentioned and the wire you mentioned to certify that it's discharged?
Check for short circuit to the case. Both terminals should have a very large resistance to the case. Your meter will likely read open if everything is good.
Yes. Just check the voltage after you apply the resistor. Also check the resistor after you use it like this.
BoB
Likes Wrichik Basu
BoB
Thanks a lot. Tell me one last thing: What does "read open" mean?
Just to be clear. Here's the case.
Yes, that I understood, but the "read open" part is unclear, rest is fine.
Set your meter to a resistance range. With the leads unconnected to anything look at the display. Digital ones often say something like "0l" or have some other display that does not make a valid number indicating it can't get a real reading. Analog meters will have an infinity sign at the rest position of the needle. That is open.
You may see the measurement jump briefly to a valid reading. This is due to the capacitance. Wait a few seconds and a good capacitor will read open between any two leads and any lead and the case
BoB
Please note (this does not apply to this exact capacitor): Some capacitors have extra support leads connected to the case or multiple leads for one plate. Disregard these extra leads when measuring. Polarized capacitors must be connected with the positive meter lead to the positive plate to be measured. To find the positive lead set your meter to diode measurement. The proper orientation is found when the meter reads open. This could potentially damage the capacitor if you have a really low voltage capacitor or a poorly designed meter that gives excessive current in diode check mode.
BoB
Understood completely. Thanks.:partytime:
Likes jim hardy and dlgoff
Here's the simple minded checks i do on them.
1. Is the capacitor shorted ?
Set meter to RX1 scale and check each lead to case, then from one lead to the other. It should read infinite, open, sometimes that's blank on a digital meter. If it reads less than many thousands of ohms (which is overrange on RX1) it's at least partiallly shorted.
2. Does the capacitor hold a charge ?
After reading resistance on RX1 and verifying a high reading, remove meter leads. Set meter to DC volts a low scale like two or ten.
Reconnect meter leads to capacitor. You should read a volt or two and that should drop off toward zero in a matter of seconds.
What that did is charge the capacitor from the ohm-meter, then verify the capacitor holds that charge long enough for you to swap meter scale and measure it with meter. A good capacitor will hold charge for a long time, but as soon as you connect the meter it starts to discharge through meter. Meter is probably ten megohms which would be 22.5 second time constant for your 2.25 microfarad capacitor.
Then reverse the meter wires and repeat. Capacitor should hold charge of either polarity.
3. Does capacitor have significant capacitance?
Set meter to RX1, connect to capacitor. It'll go quickly to max reading. Then swap meter leads, it should go negative for just an instant then return to max. What you're seeing is the capacitor being charged by the ohm meter.
Repeat on RX10 scale, then RX100, then RX1K, etc. Same thing will happen only slower and slower on the higher ohm scales.. When you've done enough capacitors you will develop a 'feel' for your meter and be able to estimate a capacitor's value(rough estimate) from how fast it charges on higher ohms scales.
If it charges immediately on highest ohms scale, it's lost nearly all its capacitance.
That's how a multimeter can be "A poor man's capacitor checker" .
Likes Asymptotic, dlgoff, Wrichik Basu and 1 other person
Thanks that was of great help :woot:
jim hardy said:
When you've done enough capacitors you will develop a 'feel' for your meter ...
And probably for most, doing those test will become "old hat"; never thinking of passing on those procedures. So good of you to post those "simple minded checks".
Likes jim hardy
I should have mentioned
on some aluminum electrolytics for DC applications like radios, the can itself is the negative terminal. I never encountered that in a motor capacitor though.
