- 2,076
- 140
I wasn't sure where to post this in particular, so I apologize if this is in the wrong section.
I've been getting interested in the topic of problem mapping lately. I came across this problem while reading and I'm not quite sure if I have the right idea or not.
The Question :
A problem mapping means to create an instance of one problem out of the details (or data)
of another. Suppose you wanted to prove that a solution to the Traveling Salesman Problem would provide a solution to the Hamilton Cycle problem.
What is the correct mapping to use given the current information?
Traveling Salesmen Problem ( TSP ) : http://gyazo.com/8944e64b668d3ea898662b083450d3d5
Hamiltonian Cycle Problem ( HCP ) : http://gyazo.com/865cb36a67f72cbd9db71913e1a4e076
Well, the way I thought about this was to recognize the important details of the problems and create a map from one problem to the other. The reason this would work is because we already have a solution to one of the problems, namely the TSP ( Barring its computational limits which are exponential, i.e ##2^n## ).
So first things first. I map the cities to the nodes so ##C = V##.
Now I need a way to tell the distances between the cities, but since I'm trying to map the problem, it reduces to finding distances between nodes. Suppose I denote this distance by ##d_{i,j} ≥ 0##. The distance between cities is zero only when we are already at the destination of course.
So presume we have to travel some ##n > 0## number of nodes to reach our destination, and we have a distance function ##d(v_i, v_j)## which can tell the distance between two vertices which depend on ##i## and ##j##.
Let :
##d(v_i, v_j) = 1## if ##v_i, v_j \in E##.
##d(v_i, v_j) = 2## if ##v_i, v_j \notin E##.
We can now travel along each node and find a path with a positive distance to the destination.
If the minimum length found from the start to the destination is ≤ n, then the set of cities has a Hamilton Cycle, otherwise it does not.
So the proper mapping is :
##C = V##
##B = n##
