Problem on Equilibrium ( STATICS )
  • Thread starter Thread starter lakuzamalakuzam
    Equilibrium Statics
The discussion centers on the assumptions needed to solve a statics problem involving thrust collars and moments. There is confusion regarding whether the 400 Nm moment is total or per collar, and how the negligible weight of the structure impacts the analysis. Participants highlight the challenge of having too many unknowns compared to the available equations, suggesting the need for additional assumptions. The complexity is compounded by the unclear role of the horizontal radius from point O to B. Clarification on the moment's resolution and the system's alignment is necessary for accurate problem-solving.
lakuzamalakuzam
so i was wondering what assumptions needed to make this solvable and ' support at both thrust collars can totally support the moments of 400 Nm before they slip' means which axis of moment
Is this a homework problem?
There is a contradiction, in that the “thrust collars” must withstand a moment.
Thrust would be axial, moment would be about the axis.
Is that a moment of 400 N⋅m each, making 800 N⋅m, or a total of 400 N⋅m together ?
How much does the structure weigh, is that important ?
You need to provide some feedback to the answers you receive.
Likes lakuzamalakuzam
Yeah It's a homework problem.
I'm not sure what the problem means when it says 400 NM but from my understanding i think it is in OA axis with assumption that the system is properly aligned.
The structure weight is negligible.
Is that a specified assumption, or an additional assumption ?
but then there will be 9 unknowns ( Fx ,F//OA, Fperpendicular to OA, couple in OA axis for each of the thrust collar and W) with 3 scalar equation and 1 vector equation = 4 eq
so i think i will have to make further assumptions like there are no support reaction on the upper thrust collar and now there are 5 unknowns which isn't solvable
The horizontal radius from O-B confuses things.
Too many equations, and not enough understanding of the system.
To resolve the moment, should it not be sufficient to resolve the distance of the hanging weight from ZY plane that contains the O-A axis, and the angle of the O-A axis to the horizontal ?
