• Support PF! Buy your school textbooks, materials and every day products Here!
Problem with a sequence
  • Thread starter um0123
hey denny, yea this is the kid that i was working on this for 2 hours with, and it i showed him the physics forums and now hes trapped.
plus hes into partcile physics like me!:smile:
but back to busniess.
the 3rd term is
√5 - √7
_______
-2
add that to the previous summation of:
1 - √5
______
-2
and you get:
1 - √7
______
-2
now lets see that pattern. gimme a minute.
okay, i simplify and get
√2n-1 - √2n+1
____________
4n
Try again.
What is [tex](\sqrt{2n-1})^{2}-(\sqrt{2n+1})^{2}[/tex]?
I am in the same math class as Um0123, and I currently have got
[tex]\frac{\sqrt{2n-1} - \sqrt{2n+1}}{-2}[/tex]
would squaring the fraction be a step in the right direction?
On the right track, but unfortunately you can't square this to get rid of the radicals for several reasons.
Try calculating that fraction for several consecutive values of n, and see if you notice a pattern.
is the pattern:
1 - √(n+2)
________
EDIT: DAMNIT, THAT ONLY WORKS FOR ODD TERMS!!!!
lanedance
3,304
no, try putting in the n values as a check, you will need to keep the squareroot
  • #31
lanedance
3,304
notice it is always an odd term, if N is the number of terms and S is teh sum wth N terms:
N = 1,
S(N) = (√3- 1)/2
N = 2
S(N) = (√5- 1)/2
N = 3
S(N) = (√7- 1)/2
notice it is always includes squareroot of an odd term, any ideas how to write that in terms of N?
Once you have your general equation, solve it for N, when S(N) = 100
I have to go now (good luck), but here's another more rigourous way to finish the problem:
to help see the pattern & summarise
[tex]S(N) = \sum_{n = 1}^{N} \frac{1}{\sqrt{2n - 1} + \sqrt{2n + 1}}[/tex]
after rationalising the denominator
[tex]S(N) = \sum_{n = 1}^{N} \frac{1}{2} (\sqrt{2n + 1} - \sqrt{2n - 1} )[/tex]
splitting the series & changing dummy to help with substitution:
[tex]S(N) = \frac{1}{2}( (\sum_{n = 1}^{N} \sqrt{2n + 1}) - (\sum_{m = 1}^{N}\sqrt{2m - 1}))[/tex]
now to go forward form here:
- substitute into the 2nd sum only, m = n +1
- the sum limits of the 2nd sum will now become n = 0 to n = N-1 (previously m =1 to N)
cancelling terms should lead to the same pattern you observe
  • #32
Kk, I've done some work, and I think I found a pattern to the sum.
[tex]\frac{\sqrt{2n+1}-1}{2}[/tex]
  • #33
152
thanks lanedance, and phase shifter, and to everyone who helped.
together denny and i got the answer, and we couldnt ever do it without you guys.
  • #34
277
Right.
  • #35
SWEET, thanks guys, I got the answer. All your help, from everyone, was very much appreciated.
Related Threads for: Problem with a sequence
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
