Problem with choosing which axis should be positive or negat
  • Thread starter Thread starter Frankenstein19
    Axis Positive
Choosing the positive direction in physics problems is flexible, as long as consistency is maintained throughout the calculations. In the case of the bucket problem, whether upward or downward is designated as positive does not affect the correctness of the final answer, as it will simply be the negative of the alternative choice. The key is to apply the same sign convention throughout the entire problem. Therefore, even if the signs differ from a reference solution, the answer remains valid as long as the chosen direction is consistent. Understanding this concept is crucial for solving similar physics problems accurately.
Frankenstein19
A 14.0kg bucket is lowered vertically by a rope in which there is 163N of tension at a given instant. What is the acceleration of the bucket.
ƩF = may
I know how to solve this but I got it wrong because of the signs.
Since the bucket was being lowered I thought that downward was going to be positive, but the correct solution says that up is positive; WHY?
It doesn't matter what you choose to be positive or negative. If you chose differently than the book, then your signs will be opposite at the end. That's it. As long as you're consistent, it'll be the same.
so even though its negative it's correct? or are you saying i wasnt consistent with my signs and that regardless of what i choose to be positive or negative that as long as I am consistent with it that i should get the correct answer?
If your answer is the negative of the correct answer, and you chose opposite axes as the correct answer, then your answer is also right. Yes, you can choose your positive direction to be whatever direction you want as long as it stays the same throughout the problem.
You'll get the correct answer for those axes. If you chose your positive direction to be the opposite direction as someone else, that just means your answer will be the negative of theirs.
Likes Frankenstein19
ohh ok thank you so much!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
