Problem with Limits using L'Hospital's Rule
  • Thread starter Thread starter CharlesL
    Limits
CharlesL
Determine the limit of
lim \psi\rightarrow1 of \psi^(1/(\psi-1))
Let y = \psi^(1/(\psi-1))
ln y = ln \psi^(1/(\psi-1))
lim \psi\rightarrow1 ln y = lim \psi\rightarrow1 of (1/(\psi-1)) (ln \psi)
Differentiate
lim \psi\rightarrow1 ln y = -1/(\psi-1)2 x (1/\psi)
lim \psi\rightarrow1 ln y = 2/(\psi3+3\psi2+3\psi+1)
ln y =1/4
y = e1/4
Does e1/4 = e?
L'Hopital's rule works for f(x)/g(x) and then you get f'(x)/g'(x). Try rewriting the step before you differentiate as a fraction and not a product.
Thank you for your reply.
I wonder which is the correct solution
solution (a)
ln y = 1/(\psi-1) x ln \psi
ln y = ln \psi x (\psi-1)
ln y = 1/\psi
ln y = 1/1
y = e1
or solution (b)
ln y = ln \psi / (\psi-1)
ln y = 1/\psi
ln y = 1/1
y = e1
I did it the second way, assuming you just didn't feel like typing out that you were still dealing with limits
Thank you Hogger for your point outs. Appreciate it. Have a nice day
Charles
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
