Problem with the change of variable theorem of integrals
The discussion revolves around a problem with the change of variable theorem in integrals, specifically regarding the integral ∫ from 0 to 1 of x√(1-x²). The user attempted to solve the integral using two different intervals for the variable transformation, both yielding contradictory results in sign. The first approach, using g(x) = cos(x) over [0, π/2], resulted in a positive value of 1/3, while the second approach over [-π/2, 0] led to a negative value of -1/3. The confusion arose from not accounting for the absolute value of sin(x) in the second interval, which was clarified by another participant. The user acknowledged the oversight and expressed gratitude for the correction.
IvanT
So I came across the integral \int^{1}_{0}x\sqrt{1-x^2} and I tried to solve it in two ways using the change of variables theorem for integration, however both ways are supposed to give me the same result, but they differ in the sign and I cannot find what I am doing wrong.
The change of variable theorem states the following: Let I=[a,b]. Let g: I->R be a function of class C^1, with g'(x) different from 0 for x in (a,b). Then the set g(I) is a closed interval J with end points g(a) and g(b) (not necessarily in that order). If f: J->R is continous, then \int^{g(b)}_{g(a)}f=\int^{b}_{a}(f°g)g'
So, for the first solution I used g(x)=cos(x) in the interval I=[0,Pi/2]. Clearly cos(I)=[0,1] and g'(x)=-sin(x) is not 0 for any x in (0,pi/2). Since f(x)=x*sqrt(1-x^2) is continuous in [0,1] the hypotheses of the theorem are satisfied and we have \int^{g(pi/2)}_{g(0)}f=\int^{0}_{1}x\sqrt{1-x^2}=-\int^{1}_{0}x\sqrt{1-x^2}=\int^{pi/2}_{0}cos(x)sin(x)(-sin(x))=-sin^3(pi/2)/3+sin^3(0)/3=-1/3 so that \int^{1}_{0}f=1/3.
On the other hand, if I consider the same g(x)=cos(x) but now in the interval I=[-pi/2,0], we have again that cos(I)=[0,1] and the hypotheses are satisfied. However we get \int^{g(0)}_{g(-pi/2)}f=\int^{1}_{0}x\sqrt{1-x^2}=\int^{0}_{-pi/2}cos(x)sin(x)(-sin(x))=-sin^3(0)/3+sin^3(-pi/2)/3=-1/3 so that \int^{1}_{0}f=-1/3!.
I checked every step a few times already and I cannot find the mistake. Any help would be appreciated.
When you took √sin2(x), it's |sin(x)|, which in the second region is -sin(x)
Oh xD, I didn't noticed that, thanks a lot : ).
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 19 ·
