C/C++ Problem with the Haversine Formula in C++ Help
  • Thread starter Thread starter DeepSeaBiscuit
    C++ Formula
The discussion centers on a C++ program using the haversine formula to calculate the distance between Swansea and Cardiff, which is expected to be approximately 55.02 km. However, the program initially returns a distance of 28.30 km. The user shares their implementation of the haversine function, which includes a conversion from degrees to radians and calculations for distance. Key issues identified include the use of an imprecise value for π and the incorrect handling of latitude and longitude conversions. After adjustments, including using a more accurate π value and correcting the distance calculation method, the user discovers that converting latitude and longitude to radians individually resolves the issue, leading to accurate distance results. Additionally, the discussion highlights the importance of using a more precise radius for Earth in calculations, as the default value may lead to significant errors over larger distances. Suggestions for improving accuracy include using the WGS-84 ellipsoid model and ensuring that constants like π and the Earth's radius are defined with higher precision.
DeepSeaBiscuit
Hello, I have the haversine function within my C++ program to calculate the distance between to points, the two tester points I have chosen are Swansea and Cardiff both located in Wales.
Swansea lat = 51.622559, long = -3.934534
Cardiff lat = 51.475661, long = -3.174688
The problem I am having is that the actual line distance for these two points is 55.02 km but my program keeps giving out 28.30 km and I am not sure why?
My function that I am using to calculate the distance is #include <cmath>
using namespace std;
double calcDistance(double lat2, double lat1, double long2, double long1)
double toRadians = 3.1415 / 180;
double dLat = (lat1-lat2)*toRadians;
double dLong = (long1-long2)*toRadians;
double a = pow(sin(dLat / 2), 2) + cos(lat1)*cos(lat2)*pow(sin(dLong/ 2),2);
double c = 2 * atan2(sqrt(a), sqrt(1-a));
double R = 6371;
double distance = R * c;
return distance;
Any help?
Technology news on Phys.org
My function that I am using to calculate the distance is#include <cmath>
double R = 6371;
return distance;
Any help?
What you calculate for a looks OK as far as it goes. The wikipedia page (http://en.wikipedia.org/wiki/Haversine_formula) differs from what you have for the code after your calculation of a.
It gives this for the great circle distance: d = 2r * arcsin(##\sqrt{a}##).
BTW, your value for ##\pi## is not very precise. You could do much better using 4.0 * atan(1.0).
I have altered the function according to what you suggested however this still hasn't solved the issue some how? As a calculated distance I get 5926.76 km which isn't too far off the radius of the earth! I have been stuck on this problem for a day now I really can't figure out the problem? Could there be something else I'm missing?
double toRadians = 3.14159265359 / 180;
double R = 6371;
double distance = 2*R*asin(sqrt(a));
return distance;
I may have figured the problem out, I converted the lat and long individually from deg to radians and the program works perfectly! Thank you for the help!
Your value for R will cause you grief - the Earth is a spheroid - like a ball with middle age spread. The WGS-84 ellipsoid has:
Equatorial radius (6,378.1370 km)
Polar radius (6,356.7523 km)
Which, going from the equator to the poles, with all other considerations ignored is 3m/km. Beyond a few hundred km this error can become unacceptably large. Which is the exact idea Mark44 is trying to convey about the PI constant you have. In C/C++ the default precision for a double is 15 digits. So you may want to tweak your code to actually work to something closer to that level of accuracy. The radius for your example should be correct to 8 significant digits. Ditto PI. Not four. Nine would be better for all possible inputs.
Google for Meridional radius or Gauss radius of curvature maybe. Usually a decent app using haversines will calculate distances over small changes in Lat with a recalculated radius for each Lat delta.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
