How to Solve the Integral of e^x ln(x) dx?
  • Thread starter Thread starter ultrazyn
    Integral
ultrazyn
i need help with this integral
\int{e^x}{ln{x}}dx
when i let u=ln(x) and v=e^x, i get
\{e^x}{lnx}\ - \int{e^x/{x}}dx
and then it keeps looping
What do you mean by "it keeps looping?"
If by "looping", you mean that you let dv= \frac{1}{x} and u= e^x and everything canceled out leaving you with
\int e^x lnx dx= \int e^x ln x dx[/itex]<br /> Of course!<br /> <br /> If you do integration by parts twice and the second time &quot;swap&quot; u and dv, that will always happen.<br /> <br /> Perhaps what you mean is that you again let dv= e^x and u= \frac{1}{x} so that you would up with<br /> e^x lnx dx= e^x lnx- \frac{1}{x}+ \int\frac{e^x}{x^2}dx[/itex]&lt;br /&gt; and continuing just gives you higher and higher powers in the denominator: Okay, that&amp;#039;s good. What eventually happens is that, in the limit, you get ln x plus an infinite series. The integral cannot be done in terms of &amp;quot;elementary&amp;quot; functions.
If, when solving by parts, you ever end up with your original integral, you can substitute a algebraically (like substitute the letter I for the origingal integral anywhere you see it) then just solve for I and that's your solution.
My professor broke solving by parts into three different types, and he called that one "around the world"
&lt;br /&gt; &lt;br /&gt; Except for the case \int_0^{\infty}dxe^{-ax}lnx=-\frac{\gamma+lna}{a} which is exact.
Your integral is a definite integral, the other is not, moreover, what is gamma?
\text{ExpIntegralEi}[x] = - \int_{-x}^\infty \frac{e^{-t}}{t} dt
Mathematica solution:
\int e^x ln{x} dx = \int_{-x}^\infty \frac{e^{-t}}{t} dt + e^x ln x
\gamma - EulerGamma (Euler-Mascheroni Constant)
\text{ExpIntegralEi}[z] = \sum_{k=1}^\infty \frac{z^k}{kk!} + \frac{1}{2} \left[ ln z - ln \left( \frac{1}{z} \right) \right] + \gamma
\int_{-z}^\infty \frac{e^{-t}}{t} dt = \sum_{k=1}^\infty \frac{z^k}{kk!} + \frac{1}{2} \left[ ln z - ln \left( \frac{1}{z} \right) \right] + \gamma
Orion1 solution:
\int e^x ln{x} dx = \sum_{k=1}^\infty \frac{x^k}{kk!} + \frac{1}{2} \left[ ln x - ln \left( \frac{1}{x} \right) \right] + e^x ln x + \gamma
Reference:
http://functions.wolfram.com/GammaBetaErf/ExpIntegralEi/02/
[/Color]
http://mathworld.wolfram.com/Euler-MascheroniConstant.html
if "lnx" is the anle of any trignometric function. like intergration of "sinln dx "
What? That made absolutely no sense whatsoever? ln(x) is the natural logarithm of x.
