Problems with a Charged Particle in a Magnetic Field
The discussion revolves around the wavefunction of a charged particle in a magnetic field, specifically addressing the Hamiltonian and the role of the vector potential A. It highlights the non-uniqueness of A due to gauge transformations, questioning whether A can be considered an observable despite its arbitrary nature. The conversation also explores the implications of choosing different vector potentials on the resulting wavefunctions, noting that certain choices can lead to unexpected behaviors, such as a particle appearing unbound in one direction. Participants emphasize that while A is not an observable, the physical effects it generates, like those seen in the Aharonov-Bohm effect, are significant. The complexities of gauge invariance and energy eigenstates in quantum mechanics are acknowledged, indicating that different gauge choices can lead to degenerate energy levels.
phi1123
I was wondering about what the wavefunction of a particle in a magnetic field would look like, so after some quick work and a little research, I found the the Hamiltonian is
\hat{H} = \frac{(\hat{p}+qA)^{2}}{2m}
where A is the vector potential such that B=×A. I thought that the vector potential was a useful fiction, like the scalar potential for the electric field, as it is not unique (adding the gradient of a scalar field to the vector potential does not affect the magnetic field, for instance). However, does its presence as an operator on ψ not mean that it is in fact an observable?
I am further confused by the specific case of a constant magnetic field. Taking the field to be B along the z axis, it can be easily verified that the corresponding vector potential would be
A = cyi+dxj such that d-c = B
The choice of c and d would appear to be arbitrary (at least classically), however they seem to affect the wavefunction. Furthermore, taking c=0, d=B, the Schrodinger equation turns into the Hamiltonian of a free particle in the x direction, and the a simple harmonic oscillator in the y direction. This is not at all what I would have expected, since classically, the particle would be in simple harmonic motion in both direction (circular motion). Why does this apparently arbitrary choice of A seem to make the particle unbound in the x direction?
The vector potential is not an observable, for the reason you mention: you could make it whatever you want just by a gauge transformation.
consider \vec{A}=B_{0}y\hat{x}\implies \vec{B}=-B_{0}\hat{z} this is a legit vector potential.
<br /> \hat{H}=\frac{1}{2m}\left( p^2 + q\vec{A}\cdot\vec{p} + q\vec{p}\cdot\vec{A} + q^2 A^2 \right)=\frac{1}{2} \left( \hat{p}^2 + 2q B_{0}\hat{y} \, \hat{p}_{x} + q^2 B_{0}^{2}\hat{y}^2 \right)<br />
where the hats denote operators at the end, not unit vectors, and [\hat{y},\hat{p}_{x}]=0.
In classical E&M we tend to take the view that E and B are fundamental, and A is a useful derived quantity. In quantum mechanics, for the reason you've found, we tend to take the view that A is fundamental and E and B are useful derived quantities. For example, see the Aharanov-Bohm effect, where a nonzero A causes quantum mechanical effects even when E and B are zero in the entire region of the experiment: http://en.wikipedia.org/wiki/Aharanov-Bohm_effect
That said, A itself is not an observable, because you can make it whatever you want by a gauge transformation. Only quantities that are unchanged by gauge transformations are observable. These include, for example, closed line integrals of the A field, which are the quantities measured in the Aharanov-Bohm effect.
I think you have to be careful about interpreting the wave functions here. First, the energy eigenstates you find may be superpositions of many degenerate eigenstates. So if you find delocalized eigenstates, that doesn't necessarily mean that there isn't a different basis of localized eigenstates that look like the classical orbiting electrons. Second, the physical momentum operator is no longer the gradient operator, so a plane wave does not necessarily represent a particle traveling unimpeded in a certain direction.
This is one of the most fascinating topics. Gauge invariance rules a lot of elementary particle physics, and electromagnetism is of course just the most simple case of such a theory. A very nice paper about gauge invariance, the AB effect, etc. is
Wu, T. T., and Yang, C. N. Concept of nonintegrable phase factors and global formulation of gauge fields. Phys. Rev. D 12 (1975), 3845.
http://link.aps.org/abstract/PRD/v12/i12/p3845
In all cases,gauge invariance is preserved i.e. it will be only line integral of A(over closed loop) which will be observable and not the A.
Okay, so I guess I'm still confused by the whole choice of Gauge thing. You say:
The_Duck said:
The energy eigenstates you find may be superpositions of many degenerate eigenstates
Does this mean that there is a degenerate energy level for each choice of Gauge? If not, how does the same state correspond to several different wavefunctions?
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 29 ·
