Problems with ground with batteries
  • Thread starter Thread starter Kerso1991
    Batteries Ground
The discussion focuses on the challenges of using battery ground in oscillator circuits, particularly the limitations of using the negative side of a battery as a reference point. It highlights the necessity of a true 0V reference for AC signals, as the negative side becomes ineffective during the negative phase. Participants emphasize that current flow depends on the presence of a proper return path, and clarify misconceptions about the "ground" analogy in electrical circuits. The concept of "virtual ground" is introduced as a potential solution for achieving a stable reference point. Understanding these principles is crucial for effective circuit design in oscillators.
Kerso1991
Hiya, I'm a bit of an intermediate in electronics and I am moving into oscillator territory and am thinking more about "ground" rather than "the negative side of the battery". Obviously, using -ve voltage as ground has some setbacks with dc-ac oscillators as current can only flow if there is a true 0v reference point(when the ac signal goes into the -ve phase then the -ve side of a battery is absolutely useless). What can I use as 0v rather than -9v on a battery that'll actually work? Considering that current cannot flow from the -ve side of one battery to the +ve side of another without the oposite polarities being connected, I'm presuming that current also cannot flow from the +v side of one battery and the ground on a mains plug.
Any help would be great
Do you believe in Kirchoff's Current Law?
Current only can go back to its source.
If "Ground" happens to provide a path back there , current might take it. Or it might not, if there's a better path.
The "water" analogy mis-leads almost all beginners because we see water fall from our garden hose to "ground".
It's gravity causing that, not some magical affinity of water for ground.
Electricity doesn't care a whit about gravity.
It has no magical affinity for "Ground" (which I prefer to call "Earth" to distinguish from "Circuit Common" aka 'ground' )
I cannot parse that statement.
Can you slow down and re-phrase it one thought at a time?
"A question well stated is half answered".
There exists a concept in circuits known as "virtual ground" midway between supply rails... maybe that's what your are considering? Try a few searches on those words.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
