Problems with Runge-Kutta method
The discussion centers on a programming challenge involving the implementation of the Runge-Kutta 4th order method to solve Kepler's problem in a Cartesian coordinate system. The original poster is struggling with errors in their code, particularly with force calculations returning zero and the program crashing at certain iterations. Key issues identified include the incorrect use of array indexing, as C-style arrays start at zero rather than one, leading to out-of-bounds errors. Additionally, the implementation of the Runge-Kutta method is flawed; the poster is advised to follow a more structured approach to the RK4 algorithm, which involves calculating intermediate values for position and velocity in a specific order. Ultimately, the poster acknowledges that the issue was computational rather than mathematical, indicating a resolution was found through community feedback and corrections.
Leonardo Machado
I'm writing a program to compute an ODE solution of the Kepler's problem based on Runge-Kutta 4th order method and today I've past the whole day trying to made it work, but I've failed, maybe you could help me to kill the problem ?
The solutions is cartesian.
Code:
int main(){
    int n;
    double tau, x[4][200], xk[4], f[4][200], GM, PI = 3.14159265;
    double f1[4], f2[4], f3[4], f4[4] ;
    GM = 4 * pow ( PI, 2);
    x[2][1]= 0;
    x[3][1]= 0;
    cout << "Insert the inicial distance ( AU): " ;
    cin >> x[1][1];
    cout << "Choose tau ( Years): " ;
    cin >> tau;
    //Circular mov condition
    x[4][1]= sqrt ( GM / sqrt ( pow ( x[1][1], 2) + pow ( x[2][1], 2)));
    for ( n=1 ; n <= 199 ; n++) {
        // Definitions of runge-kutta parametres F1, F2, F3 e F4
        xk[1]=0;
        xk[2]=0;
        xk[3]=0;
        xk[4]=0;
        f[1][n]= x[3][n] + xk[3];
        f[2][n]= x[4][n] + xk[4];
        f[3][n]= -GM * (x[1][n] + xk[1]) / pow ( sqrt (  pow ( x[1][n] + xk[1], 2) + pow ( x[2][n] + xk[2], 2)), 3);
        f[4][n]= -GM * (x[2][n] + xk[2]) / pow ( sqrt (  pow ( x[1][n] + xk[1], 2) + pow ( x[2][n] + xk[2], 2)), 3);
        f1[1]= f[1][n];
        f1[2]= f[2][n];
        f1[3]= f[3][n];
        f1[4]= f[4][n];
        xk[1]=0.5*tau*f1[1];
        xk[2]=0.5*tau*f1[2]/2;
        xk[3]=0.5*f1[3];
        xk[4]=0.5*tau*f1[4];
        f2[1]= f[1][n];
        f2[2]= f[2][n];
        f2[3]= f[3][n];
        f2[4]= f[4][n];
        xk[1]=0.5*tau*f2[1];
        xk[2]=0.5*tau*f2[2];
        xk[3]=0.5*tau*f2[3];
        xk[4]=0.5*tau*f2[4];
        f3[1]= f[1][n];
        f3[2]= f[2][n];
        f3[3]= f[3][n];
        f3[4]= f[4][n];
        xk[1]=0.5*tau*f3[1];
        xk[2]=0.5*tau*f3[2];
        xk[3]=0.5*tau*f3[3];
        xk[4]=0.5*tau*f3[4];
        f4[1]= f[1][n];
        f4[2]= f[2][n];
        f4[3]= f[3][n];
        f4[4]= f[4][n];
        xk[1]=0;
        xk[2]=0;
        xk[3]=0;
        xk[4]=0;
        x[1][n+1]= x[1][n] + tau/6*(f1[1]+f4[1]+2*(f2[1]+f3[1]));
        x[2][n+1]= x[2][n] + tau/6*(f1[2]+f4[2]+2*(f2[2]+f3[2]));
        x[3][n+1]= x[3][n] + tau/6*(f1[3]+f4[3]+2*(f2[3]+f3[3]));
        x[4][n+1]= x[4][n] + tau/6*(f1[4]+f4[4]+2*(f2[4]+f3[4]));
        cout << endl
            << "t= " << setw (6) << tau*(n-1)
            << setw (10) << "x= " << setw (6) << x[1][n]
            << setw (10) << "y= " << setw (6) << x[2][n]
            << setw (10) << "vx= " << setw (6) << f[1][n]
            << setw (10) << "vy= " << setw (6) << f[2][n]
            << setw (10) << "fx= " << setw (6) << f[3][n]
            << setw (10) << "fy= " << setw (6) << f[4][n];
Look like when it takes n=1 there is some error that make the force in x and y equals 0, as you can see in this print screen, also it crashes on n=5 :c
I would be gratefull if you help me.
Technology news on Phys.org
@Leonardo Machado, I fixed your post to use code tags rather than a bold font.
Your problem is simple: Arrays in the C family of languages start at zero rather than one.
Thanks, I'm newbie in here, sorry about the wrong format.
Dont know if i got it , but when you say it starts at zero you meant for example:
double x[4] = x[0] , x[1], x[2], x[3] and x[4], right ??
Case yes, there should not have any problem, cause I'm using n starting at 1 in the loop, these coordinates still exist.
That is not right. What double x[4] does do is to declare x as an array with four elements, accessed as x[0], x[1], x[2], and x[3]. The element x[4] does not exist.
Your code is incorrect in a number of other ways. You are not implementing RK4 correctly.
Example pseudo code RK4 step, p = position, v = velocity, a = acceleration. p[] and v[] don't have to be arrays, just using the syntax of [ i ] as a step indicator. In this case (Kepler), acceleration is a function of position (the velocity parameter is not needed).
p1 = p[ i ]
v1 = v[ i ]
a1 = f(v1, p1)
p2 = p[ i ] + 1/2 Δt v1
v2 = v[ i ] + 1/2 Δt a1
a2 = f(v2, p2)
p3 = p[ i ] + 1/2 Δt v2
v3 = v[ i ] + 1/2 Δt a2
a3 = f(v3, p3)
p4 = p[ i ] + Δt v3
v4 = v[ i ] + Δt a3
a4 = f(v4, p4)
p[ i+1 ] = p[ i ] + 1/6 Δt (v1 + 2 v2 + 2 v3 + v4)
v[ i+1 ] = v[ i ] + 1/6 Δt (a1 + 2 a2 + 2 a3 + a4)
i = i + 1
I've fixed it, thanks all of you for the contribution and ideas.
In the end, the mistake was computational, not mathematical, was something about the order that the function was presented.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
