Projectile Motion: Analyzing a Volleyball Jump Spike at Different Angles
In summary, the conversation discusses a physics problem involving a volleyball player performing a jump spike and controlling the angle of the spike. The problem is solved using equations for projectile motion, with the initial angle being 18 degrees and then changing to 8 degrees. The difference in distance on the opposite floor between the two angles is found to be 3.407 meters. The importance of considering signs and vector diagrams in solving the problem is also emphasized.
Elixer
In a jump spike, a volleyball player slams the ball from overhead and toward the opposite floor. Controlling the angle of the spike is difficult.Suppose a ball is spiked from a height of 2.30 m with an initial speed of 20.0 m/s at a downward angle of 18.00o. How much farther on the opposite floor would it have landed if the downward angle were , instead, 8.00o?
(Source - Fundamentals of PHYSICS, Halliday, Resnick,Walker, 8th edition, chapter 4, QS.33)
This is a case of projectile motion , thus,
say, initial velocity = u,
displacement in vertical direction = h
displacement in horizontal direction = s
time of flight = t
h = uyt + 0.5ayt2
s = uxt + 0.5axt2
CASE 1:angle = 18o
uy = usin(18o) = 6.18m/s
-2.3 = 6.18t -4.9t2
t = 1.562s
ux= ucos(18o) = 19.02 m/s
so, s1 = 19.02 * 1.562 = 29.71 m
CASE 2:angle = 8o
uy = usin(8o) = 2.78m/s
-2.3 = 2.78t-4.9t2
t = 1.025s
ux = ucos(8o) = 19.81m/s
so, s2= 19.81*1.025 = 20.31m:eek:
Well, I am confused.:confused:
Thank you.
-2.3 = 6.18t -4.9t^2
h, uy and ay are all in the same direction. So all should be either positive or negative.
Thank you so much! That points out the importance of signs and vector diagrams.
Yes, so the equations are:
CASE 1: angle = 18o
-2.3 = -6.18t -4.9t2
t = 0.3s
ux = ucos(18o) = 19.02m/s
so, s1 = 19.02 * 0.3 = 5.706 m
CASE 2: angle = 8o
-2.3 = -2.78t - 4.9t2
t = 0.46s
so, s2 = 19.81 * 0.46 = 9.113 m
Hence , difference = s2-s1 = 9.113 - 5.706 = 3.407 m.
ANS = 3.407m:approve:
Thank you!:cool:
1. What is projectile motion?
Projectile motion is the motion of an object in a curved path under the influence of gravity. It is a combination of horizontal motion with a constant velocity and vertical motion with a constant acceleration due to gravity.
2. What are the factors that affect projectile motion?
The factors that affect projectile motion include the initial velocity, the angle of projection, the mass of the object, the air resistance, and the height from which the object is launched.
3. How is projectile motion analyzed?
To analyze projectile motion, you need to break down the motion into its horizontal and vertical components. Then, use equations of motion to calculate the displacement, velocity, and acceleration of the object at different points in its path.
4. What is the trajectory of a projectile?
The trajectory of a projectile is the path that the object takes through the air. It is a parabolic curve, as the object follows a constant horizontal velocity and a constant vertical acceleration due to gravity.
5. What are some real-life examples of projectile motion?
Some real-life examples of projectile motion include throwing a ball, a bullet fired from a gun, a basketball being shot into a hoop, and a rocket launched into space.
