Projectile Motion Collision Problem
A particle P is projected from the origin with an initial speed of 5 m/s at an angle θ, while another particle Q moves along the x-axis with an initial speed of 15/4 m/s and a constant acceleration of 3g/4 m/s². The challenge is to determine the time of collision and the distance from the origin where this occurs, but the unknown angle complicates the equations. The participants discuss the correct equations for both particles, noting that the angle θ is crucial for solving the problem. Ultimately, the solution involves isolating time from the vertical motion equation and equating it to the horizontal motion equations to find the angle, time, and distance of collision. The final results indicate a launch angle of approximately 16.25°, a collision distance of about 1.37 meters, and a time of 0.29 seconds.
TheRedDevil18
A particle P is projected from the origin with initial speed 5 m/s and projection angle theta. At time t = 0, when P is at the origin, another particle Q begins to move on the
(horizontal) x-axis with initial speed 15/4 m/s and constant acceleration a = 3g/4 m/s^2.
Determine the time t when P collides with Q, and the distance from the origin where this
occurs.
I know the times are the same but I can't solve for the equations because the angle is unknown. Any advice on how to go about solving this ?
What are the equations? Show them, please. The angle is one of the unknowns.
ehild
ehild
Δy = V0SinΘ - 1/2 gt^2
Knowing that delta y = 0,
0 = 5SinΘ - 1/2 (-9.8)t^2.....1
x = V0t - 1/2at^2, this is for particle q
x = (15/4)t - 1/2(-9.8)t^2......2
If the angle was given this could have been easily solved because the times are the same for P and Q
If I'm not misunderstanding the problem, then there is only one angle in which the particles collide (i.e. there's only one angle in which the paths intercept at the same time)
This is how you know which angle to use.
P.S.
Are we supposed to assume the position of Q at t=0 is at the origin?
Edit:
Don't you mean plus 1/2at^2?
That is not the acceleration that was given for particle Q
What about the x coordinate of particle P?
As Nathanael pointed out, particle Q does not accelerate with -9.8 m/s^2. And in general, x= vot+a/2t^2 is the formula for the x displacement in case of uniformly accelerating motion.
ehild
ehild
Yes, my mistake
For particle Q
x = (15/4)t + 1/2(7.35)t^2...,
@Nathanael, why is it plus 1/2 at^2 ?, I thought the formula had a minus sign in it
The X co-ordinate of particle P is,
x = 5cosΘt
I don't know if we can assume that the Q started at the origin else their displacements should be the same. Still don't know how to get the angle though
I think that if we don't assume that Q started at the origin, then the problem is unsolvable (as far as I can tell).
It only has a minus sign if the acceleration is "negative" (which is just a direction).
Consider the case of zero initial velocity and a positive acceleration. The formula becomes x=\frac{1}{2}at^2.
If the acceleration is (in the) positive (direction), wouldn't you expect the displacement to be (in the) positive (direction)?
Have you thought about it? Can you elaborate on why you're stuck? Contemplate it a bit.
I haven't gone through a specific solution, but I can tell you that each angle corresponds with one-and-only-one final distance, and one-and-only-one "time in the air"
The other particle must be at that same distance at that same time. So you will need to find the angle which works.
(It's like a game where you're tring to land one particle on the other particle by altering the launch angle)
(Except you have physics/math, so you will beat the game first try :-p)
TheRedDevil18 said:
Yes, my mistake
For particle Q
x = 5cosΘt
You have three equations and three unknowns: the angle θ, the time t and x.
x=5cos(θ) t
y=0=5sin(θ) t -g/2 t2
I assume you can solve a system of equations.
You need t and x in the final result. It would be nice to eliminate the angle θ. It is a good method to use that sin2(θ)+cos2(θ)=1
ehild
Thanks guys, I finally solved it
I got my time to be 0.29's and displacement to be 1.39m
Thanks again to ehild and Nathanael :)
By trial and error, i agree, with g @ 9.8 (m/s)/s, the result is :
launch angle = 16.25 °
x distance to collision = 1.3707 metres
elapsed time = 0.2855 seconds
Well done!
I have just noticed that a =3/4 g was given. So the evaluation can be much simpler.
x=5cos(θ) t
x = (15/4)t + 1/2(3g/4)t^2
You could have done it on a more straightforward way:
Isolate t from the second equation: ##t=\frac{10}{g}\sin(θ)##
Equate the first and third equations and divide by t.
##5\cos(θ)=\frac{15}{4}+\frac{3g}{8}t##
Substitute t=10/g sin(θ) for t:
##5\cos(θ)=\frac{15}{4}+\frac{3g}{8}\frac{10}{g}\sin(θ)\rightarrow 5\cos(θ)=\frac{15}{4}+\frac{15}{4}\sin(θ)##
Multiply by 4/5:
##4\cos(θ)=3+3\sin(θ)##
take the square, substitute cos2(θ)=1-sin2(θ) and solve for sin(θ).
sin(θ)=0.28, θ=16.26°
ehild
