Projectile motion with a region of 0 acceleration
The discussion revolves around calculating the x-component of the initial velocity (Vi) in a projectile motion scenario with varying acceleration. The user has established known values for distances and acceleration, along with a total time of 3 seconds for the motion. They derived equations based on kinematic formulas but are struggling to isolate Vi from the resulting equation. The key challenge lies in simplifying the equation while incorporating the total time constraint. The user seeks guidance on whether their approach is correct or if there is a more efficient method to determine Vi.
suchara
I don't know if the title is misleading or not because I can't think of anything better ..
I need help with something I've been working on... its not homework...its more of a side project/hobby of mine, but i couldn't figure out where to put this question..
Basically I need to figure out the x-component of the initial velocity
So let's call it Vi
Heres the scenario
http://img27.imageshack.us/img27/5536/sce1d.jpg
The known values are
d1= 10
d2= 10
d3= 10
a = 10 during d1 and d3 and a = 0 during d2 (see pic above)
and t1+ t2 + t3 = 3 seconds
Vf = Vi + a*t
d= Vit + 0.5*a*t^2
d = v*t (if acceleration = 0)
vf^2 = vi^2 + 2ad
So basically I started off with the following 3 equations, I only used the first three equations from above
d1 = Vi*t1 + 0.5*a*t1^2
d2 = V2*t2 (since acceleration = 0)
Since V2 = Vi + at1, then
d2 = (Vi + a*t1)t2 = Vi*t2 + a*t1*t2
d3 = V2*t3 + 0.5*a*t3^2
or in terms of Vi
d3 = Vi*t3+ a*t1*t3 + 0.5*a*t3^2
d1+d2+d3= Vi*t1 + 0.5*a*t1^2 + Vi*t2 + a*t1*t2 + Vi*t3+ a*t1*t3 + 0.5*a*t3^2
Then I rearranged the equation to get
dtotal = Vi(t1+t2+t3) + (0.5*a*t1^2 + a*t1*t2 + at*t1*t3 + 0.5*a*t3^2)
Mutiply both sides by 2 to get rid of 0.5
2*dtotal = 2*Vi(t1+t2+t3) + a(t1^2 + 2*t1*t2 + 2*t1*t3 +t3^2)
After plugging in the known values, this is the point I am stuck at
60 = 6*Vi + 10(t1^2 + 2*t1*t2 + 2*t1*t3 +t3^2)
Is there any way I can reduce the above equation knowing t1+t2+t3 = 3 to find out Vi?
Or maybe I am doing this completely wrong and there's a better way to find out Vi given the scenario??
I can visualize the problem this way.
A particle is projected with an initial velocity V making an angle of projection theta.When it reaches the maximum height, its velocity is horizontal. It lands on a table of length 10 m with frictionless surface. At the end of the table it travels in the similar way as in the first case with reversed direction.
With these hints try to solve the problem.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
