Projectile motion with acceleration and vectors
To solve the problem of the fox jumping over a fence, it's essential to start by listing the equations of projectile motion and identifying the known variables: initial velocity, angle, and distance from the fence. The fox's jump can be analyzed by breaking down its motion into horizontal and vertical components. Calculating the time of flight and the maximum height reached will help determine if the fox clears the 0.730 m fence. It is crucial to show any initial work or calculations to receive further assistance. Understanding these steps will facilitate finding the solution effectively.
bkmurphy
A fox fleeing from a hunter encounters a 0.730 m tall fence and attempts to jump it. The fox jumps with an initial velocity of 7.10 m/s at an angle of 45.0°, beginning the jump 2.11 m from the fence. By how much does the fox clear the fence? Treat the fox as a particle.
Welcome to PF.
First thing you need to do to solve this problem is to show us what you've already done.
before someone can help you we need to see what you've already started. to give you a hint.. list down all the equations for projectile motion.. identify what is already given in the problem.. what is asked? then after that.. figure out what equation to use based on the quantities you have and the quantity you are looking for. I hope this helps :)
