Proof Help: Proving one to one and onto
  • Thread starter Thread starter kamui8899
    Proof
kamui8899
Hello, I was having trouble proving that two functions are one to one and onto.
For one:
S = {x is an element of all reals: x = (n^2 + sqrt(2))/n, n is an element of naturals numbers}
Define f: Natural Numbers -> S by f(n) = (n^2 + sqrt(2))/n
We have to show that f is onto.
So I believe what we have to do is show that there exists an n such that f(n) = t where t is an element of S for any t?
So how would we go about that, do we solve the equation for t?
t = (n^2 +sqrt(2))/n
nt = n^2 +sqrt(2)
n(t-n) = sqrt(2)
... but of course the small sequence we just went through proves absolutely nothing?
I'm having a similar problem with proving that the function:
For f: Natural Numbers -> set of all Integers
f(r) = (1 + ((-1)^r)*(2r-1))/4
is bijective
For one to one I tried the contrapositive, set f(a) = f(b) for some a, b.
So I set the equations equal to each other and simplified to:
((-1)^a)*(2a-1) = ((-1)^b)*(2b-1)
but I can't see how to simplify this down to show that a=b...
I'm having a similar problem with onto, using the same idea as we used for the first problem:
Let q be an integer.
q = f(n)
4q - 1 = ((-1)^n)(2n-1)
What can I show from here?
Any help is appreciated, thanks.
Go back to the definition of S. What, precisely, does this notation mean?
<br /> S := \left\{ x \in \mathbb{R} \, \left| \, \exists n \in \mathbb{N} : x = \frac{n^2 + \sqrt{2}}{n} \right\}<br />
In particular, if you know t \in S, what does this definition tell you?
Thanks for the reply.
You may have to help me out here a bit, as far as I know the notation means that t is an element of all real numbers such that it is equal to the equation for some natural number n. Thus every natural number has some t value, so we have to find the inverse of the function to solve for n, so then we can show that for any t we can obtain some n. I think this is what I’m supposed to do? But I’m not entirely sure if that's correct/how to do that, I tried solving for t and it didn't work, so I'm not entirely sure what your question is implying, unless I interpreted the question incorrectly?
Regarding the first part you are probably over analyzing the question. S is the set of all reals FOR WHICH there exists an n in N SUCH THAT
x=(n^2+sqrt(2))/n. Therefore S is the set
S=(1+sqrt(2), (4+sqrt2)/2, (9+sqrt(2))/3, ...). To show that f is surjective you must show that for any s in S, there exists an n in N, such that s=f(n). By the definition of f this turns out to be rather trivial.
Pick an arbitrary s in S, then we know there exists an n in N such that s=(n^2+sqrt(2))/n, but this is precisely the definition of f(n). Therefore the mapping is surjective.
for the 1st part f(\sqrt{ny-\sqrt{2}}) = x & f(-\sqrt{ny-\sqrt{2}}) = x, so x is the image of some element of that set S, showing that f is onto.
the 2nd one is similar. & just set f(x)=f(y) & do some algebra to get x=y.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
