What is the significance of p being prime in proving Fermat's Theorem?
  • Thread starter Thread starter PsychonautQQ
    Proof
PsychonautQQ
In proving Fermats Theorm, I got confused trying to follow one of the steps.
Theorm: If p is prime, then:
a^p~a (mod p).
part of proof:
multiply all the nonzero elements in Z_p by a to obtain
[a][1],[a][2],...,[a][p-1].
These are all distinct elements and none equal [0], so they must be the set of all nonzero elements [1],[2],...,[p-1] in some order. In particular, the products are the same and we obtain
([a]^(p-1))([1],[2],...,[p-1]) = ([1],[2],...,[p-1])
That fact that those last parts equal each other is confusing me, help?
Don't you mean ([a]^(p-1))([1][2]...[p-1]) = ([1][2]...[p-1])?
And if that is what you mean, does your question still stand?
a^p~a (mod p).
part of proof:
Firstly, you can consider Euler's theorem too.
So we know that the set Q = { a*a_1 , a*a_2, .., a*a_p-1 } includes all elements in the set B = {a_1, a_2, .., a_p-1 } in mod p.
We know that from the property that
" if (a,p) = 1, we can get rid of the a in the equation :
a*a_i = a*a_j (mod p) ⇔ a_i = a_j (mod p) "
Which means that all elements in Q are distinct. And they are equal to one and only one of the elements in B.
So we get
(a*a_1) * (a*a_2) * .. * (a*a_p-1 ) = a_1 * a_2 *..* a_p-1 (mod p)
a^(p-1) * A = A (mod p)
a^(p-1) = 1 (mod p).
end of the proof.
In addition to what is said above, you will need to state this restriction on the part you are doing: ##p## does not divide ##a##, or ##p \nmid a##.
The case of p divides a, ##p \mid a##, will need to be discussed separately.
As I told above;
you can't get rid of a if you don't have (a,p) = 1 property. And that prop. is given in the theorem.
This is true, it may be given in the assignment since this case is trivial.
OP, the key here is that if p is prime, and a and b are both not multiples of p, then ab is not a multiple of p. Do you see why this makes the left product one of p-1 distinct classes none of which are [0]?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
