Proof that (n+1)/(3n-1) converges to 1/3
  • Thread starter Thread starter kolley
    Proof
The discussion revolves around proving that the sequence (n+1)/(3n+1) converges to 1/3. Participants are exploring the mathematical reasoning behind this convergence and the appropriate methods to demonstrate it formally.
  • The original poster attempts to manipulate the expression to find a suitable form for proof but expresses uncertainty about how to proceed. Some participants suggest using L'Hôpital's rule, while others question how it fits into a formal proof for sequences. There is also discussion about whether an "N-ε" proof is necessary.
Participants are actively engaging with the problem, offering hints and alternative methods. There is a mix of approaches being considered, including L'Hôpital's rule and direct manipulation of the sequence. Some clarification on the original poster's calculations has been provided, but no consensus has been reached on a single method to proceed.
There is mention of potential typos in the original poster's calculations, specifically regarding the denominator in their expression. Additionally, the requirement of using "N-ε" proofs is under discussion, which may influence the approach taken.
kolley
prove (n+1)/(3n+1) converges to 1/3
I have been trying to figure this out for a while. I started out
(n+1)/3n+1)-1/3=(2n+2)/(9n-3) now I don't know how to proceed with the proof. What do I set N equal to? And then how do work it back into my inequality chain? Working this out step by step would be greatly appreciated.
Hint: L'Hôpital's rule.
how does L'Hopital's rule get incorporated into a formal proof for a sequence converging. I don't understand
Are you required to use an "N-\epsilon" proof? If not, then you can use L'Hopital's rule- although even then, I would consider it "overkill". If you are not required to use L'Hopital, just divide both numerator and denominator by n and use the fact that 1/n\to 0 as n goes to infinity.
If you are required to use "N-\epsilon":
To start with you are completely wrong in saying that (n+1)/3n+1)-1/3=(2n+2)/(9n-3). I presume the denominator, 9n-3 instead of 9n+3, is a typos but even so,
\frac{n+1}{3n+1}- \frac{1}{3}= \frac{3(n+ 1)- (3n+1)(1)}{3(3n+ 1)}= \frac{3n+ 3-3n-1}{9n+ 3}= \frac{2}{9n+1}
That is, you need to make
\left|\frac{n+1}{3n+1}- \frac{1}{3}\right|= \frac{2}{9n+1}< \epsilon
it should be easy to continue from there.
