Propagation of Error/Uncertainty
  • Context: Undergrad
  • Thread starter Thread starter luma
    Propagation
5 replies · 5K views
luma
I'm trying to get an intuitive sense for errors and picked some random numbers:
x = 2.5 +/- 0.01
find f(x) = x³
d f(x) / dx = 3x²
d f(x) = 3x² dx
= 3(2.5)² 0.01
= 0.1875
What I don't get is why f(x - Δx) ≠ f(x) - 0.1875 and why f(x + Δx) ≠ f(x) + 0.1875
Where did I go wrong in my method for finding the uncertainty value? Thanks
I found a webpage which lists:
[tex]Q = a^n \Rightarrow \frac{\Delta Q}{Q} = |n| \frac{\Delta a}{a}[/tex]
Applying the method I used in OP here,
[tex]\frac{\delta Q}{\delta a} = n a^{n-1}\\<br /> \delta Q = na^{n-1}\delta a\\<br /> \therefore \frac{\delta Q}{Q} = \frac{na^{n-1}\delta a}{a^n} = n \frac{\delta a}{a}[/tex]
So it looks like my method of deriving the uncertainty is correct.
Working out f(x) = x^6; x = 25 +/- 1 I get do,
f(25 - 1) = f(24) = 191102976
f(25 + 1) = f(26) = 308915776
now using the identity df(x) = 6 25^5 * 1 = 58593750
25^6 + 58593750 ≠ (25+1)^6
25^6 - 58593750 ≠ (25-1)^6
Any ideas?
Yes, you can think of a small error as an "differential" and approximate errors in functions of the measurement using the derivatives.
If [itex]y= x^2[/itex] then [itex]dy/dx= 2x[/itex] so that [itex]dy= 2xdx[/itex]. You could also say, then, that
[tex]\frac{dy}{y}= \frac{2xdx}{y}= \frac{2xdx}{x^2}= 2\frac{dx}{x}[/tex]
so that the "relative error", the actual error in the measurement divided by the measurement, is multiplied by 2.
More generally, if f(x,y)= xy, where x and y are independent measurements, then [itex]df= ydx+ xdy[/itex] and so
[tex]\frac{df}{f}= \frac{ydx+ xdy}{xy}= \frac{dx}{x}+ \frac{dy}{y}[/tex].
This is equivalent to the old engineering "rule of thumb": "When measurements are added, their errors add, when measurements are multiplied, their relative errors add".
Thank you for your informative post.
But what I still don't get is what they are showing?
If I make a measurement of x = 2 +/- 1 otherwise written as x = [1,3]
Then y = x² would be [1,9]
Using the rule derived dy = y (2 dx / x) = 2 x dx = 2*2*1 = 4
y = 2² +/- 4 = [0,8] ≠ [1,9]
So what does this represent intuitively?
Is this only an approximation? It doesn't look like it should be
Using the derivative is basically a way of saying "We're going to assume our function really looks like a line, and use the slope of that line to figure out what the error is".
The bigger your interval, the more room for error as the tangent line becomes a worse and worse approximation.
Notice that [0,8] is the range of the tangent line at x=2 over the interval[1,3]
