Propagator using Functional QFT
jfy4
Hi,
I am trying to write down the propagator for a scalar field theory, but I want to try and get it in the functional representation. My plan is to compute the following:
<br /> \langle \psi (x&#039;, t&#039;) | \psi (x,t) \rangle <br />
which gives the amplitude to go from x' to x. Now I guess I have to interpret this state as the ground state of the scalar field, since next I want to drop in a complete set of states
<br /> \langle \psi (x&#039;, t&#039;) | \psi (x,t) \rangle = \int \mathcal{D}\phi \, \langle \psi (x&#039;, t&#039;) |\phi \rangle \langle \phi | \psi (x,t) \rangle = \int \mathcal{D}\phi \, \psi^{&#039; *}[\phi] \, \psi [\phi]<br />
Is this procedure correct so far? Can I assume the wave functional is the ground state of the field theory in order to continue? Thanks.
Wait, I think I got it. For a free scalar field the propogator would be like
<br /> \langle 0 | \varphi (x) \varphi(x&#039;) | 0 \rangle<br />
Then we put in a complete set of eigenstates
<br /> \int \mathcal{D}\phi \, \langle 0 | \varphi (x) | \phi \rangle \langle \phi | \varphi(x&#039;) | 0 \rangle = \int \mathcal{D}\phi \, \phi(x) \, \phi(x&#039;) \, \psi^{*}_{0}[\phi] \, \psi_{0}[\phi] <br />
Next would be to explicitly calculate what \psi_{0}[\phi] would be and then do the functional integral I believe.
Ah, the generating functional approach, I am trying to stay away from that right now. I want to compute the two point correlation function for a free scalar field theory using "wave functional" representation. I'm still trying to make it work though . . .
currently, I am working with the lowering operator
<br /> a(\vec{k}) = \int d^3 x \, e^{-i \vec{k}\cdot \vec{x}}(\omega(\vec{k})\varphi(x) + i\pi(x) )<br />
and solving for \Psi_{0}[\tilde{\phi}] using
<br /> a(\vec{k}&#039;)\Psi_{0}[\tilde{\phi}]=\omega(\vec{k})\tilde{\phi}(\vec{k}&#039;)\Psi_{0}[\tilde{\phi}]+\frac{\delta \Psi_{0}[\tilde{\phi}]}{\delta \tilde{\phi}(\vec{k}&#039;)}=0<br />
and I get
<br /> \Psi_{0}[\tilde{\phi}] = N \exp \left[-\frac{1}{2} \int d^3k \, \tilde{\phi}(\vec{k})\omega(\vec{k}) \tilde{\phi} ( \vec{k} ) \right]<br />
Now I am in the process of solving the gaussian integral
<br /> \int\mathcal{D}\tilde{\phi} \, \tilde{\phi}(\vec{k})\tilde{\phi}(\vec{k}&#039;) \, \Psi_{0}^{*}[\tilde{\phi}] \, \Psi_{0}[\tilde{\phi}]<br />
but I can't seem to get it to work yet . . .
it does not seem that it will work.Are you sure with it?
You have to be careful here. You're probably using a coherent-state basis, which is a basis corresponding to eigenvalues of the field operators. This basis is overcomplete, so you need a compensating factor for this. Look at for instance Altland and Simons.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
