Proper chemical to dissolve/decompose adhesive scotch tape
  • Thread starter Thread starter Mohiuddin Munna
    Chemical
The discussion focuses on finding a chemical solution to dissolve adhesive tape without damaging GaN IC die. Acetone is suggested as it weakens or dissolves many adhesives, and soaking the tape in acetone overnight may be effective. Hexane is also mentioned as a potential option for dissolving the adhesive. The goal is to safely remove the tape while preserving the integrity of the IC die.
Mohiuddin Munna
I put few IC die (GaN grown on Si ) in small plastic case on top of scotch tape so that it can't movie . Now I it firmly stuck on it. I try to move it physically by a niddle and twister and already broke one. I need a chemical which will dissolve the tape including adhesive but not the die. Would you please
So what's the proper chemical to dissolve/decompose adhesive tape?
Thanks for your help.
Chemistry news on Phys.org
Acetone weakens or dissolves many common adhesives .
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
