Proper time of a 'half-moving object'
  • Thread starter Thread starter durant
    Proper time Time
durant
As I've red, we can measure the proper time of an object with a clock that is at rest with respect to the object. So, how would we measure the proper time of an object that is partially moving and partiall at rest. For instance if I'm moving my head and the rest of my body is at rest, how would this situation be measured? Or how would the rest frame of me in that 'situation' be defined?
You wouldn't, because there is no such thing as "the" proper time of such an object. Different parts of the object that are in relative motion will have different proper times.
It wouldn't, because there would be no such thing as a single "rest frame" that is yours. Your head would have one rest frame, and the rest of your body would have another.
But shouldn't my body, as a whole, have its unique worldine/worldtube?
Worldtube, yes. Worldline, no. Points have worldlines, objects have worldtubes.
The worldtube is the collection of all the worldlines, one for each point of your body. Trace the path of a single point on your body through spacetime, and you'll have a single worldline; put all of these worldlines together like fibers in a bundle and you'll have a world tube.
Yes, I got that. And thank you for the explanation. What I was referring to is the possible implication of the things DaleSpam mentioned. My opinion is that my body, and any other body that is 'partiall-moving' should have its rest frame because that 'allows' the sequence of timelike-events of that body. It sounds absurd to say that my body as a whole doesn't follow the transition from 'state A' to 'state B', which are timelike events.
As was already mentioned it is an extended object so it has a worldtube, not a worldline. In this case the worldtube would look somewhat like a trumpet. There is no inertial coordinate system where a trumpet-shaped worldtube is entirely parallel to the time axis.
Your opinion is incorrect.
Draw a trumpet on a piece of paper. Then try to rotate the piece of paper such that each part of the trumpet is vertical.
And yours is, of course, correct, because you are the omnipotent relativity expert.
Why are you so hard on me, first closing the thread, and then brutally discrimnating what I just wrote. Can you rather explain how is this possible, since all I read is that we define proper time with the events on the worldtube, and we define it as the one measured from the rest frame..
So in one sense you're saying that there exists a worldtube, but no rest frame. How would we know what's happening with the worldtube? And I don't mean any childish 'challenges' to you by this question, cause I'm aware and respect your knowledge, I just want the appropiate answer that makes sense.
To understand physics beyond simple classical physics, you need to expand your sense of what makes sense. Both relativity and quantum theory radically diverge from everyday physical intuition.
Specifics:
For a body, if the constituent parts are in relative motion (turning your head), then there is no rest frame for the object as a whole. Period. There are different frames in which different parts of your body are at rest. Each part of your body will have its own proper time. FYI, your head is older than your feet unless you've spend most of your life sleeping like a bat.
Specifics:
On what basis would my head be older than my feet?
Why? Because you ask a question, and get the same perfectly correct answer from multiple sources, and then insist on arguing about it based on nothing other than your preconceptions about how the universe should work. Why bother asking the question if you don't want the answer? It is obnoxious.
The fact is that the universe doesn't conform to your preconceptions. The sooner you recognize that (as we all have had to do) the sooner you can make some actual progress.
Yes. In order for there to be a single rest frame there must be a frame where all of the worldlines composing the worldtube are parallel to the time axis. Since the worldlines are not parallel to each other it is not possible for them to all be parallel to another line. This is straightforward geometry.
We don't need a rest frame to know what is happening with the worldtube. We can calculate anything that we would like to calculate about the worldtube from any frame at all. That is the whole point of the first postulate of relativity.
The answers you have received to your questions here on this forum are universally correct and make sense. They may not conform to your preconceptions, but they are correct.
You're wrong, I'm open to make adjustments on the stuff you guys state, and I respect it. Maybe the problem is my lack of understanding, or mabye the problems is your definition about some things. When you're answering me, you simply state a number of definitions that you probably have in your head without thinking that I'm not in the same knowledge positon as you are. You're attitude is like everybody who's not familiar with relativity is inferior. Secondly, I'm from Croatia, so I put a lot of effort in using english to describe some complicated terms, or to understand some phrases that you guys use when typing on the forum. Again, I'm not some ignorant person who comes here to disrespect your words and knowledge, I want to learn about it, and if you're a polite forum member you will have the patience for me to get through this and understand it.
So, back to the basic question, the object that I described has a worldtube, that's beyond doubt, right? How could we know what's happening inside it? Does the entity that we speak of have stages of its existence which are timelike events? Basically, what I've been searching for is the answers about the properties of that kind of object.
Mostly because it is at higher average elevation than your feet. Thus if there were a particle of uranium lodged in your head, and another in your foot, the one in your head would have emitted more alpha particles over your life (a direct measure of age). This is due to what is called gravitational time dilation. Sticking to special relativity, if you were in deep space and did a lot of activity with your hands, then your hands would be younger than your torso.
So, all observers will agree about the sequence of events and properties of the worldtube?
PAllen said:
Mostly because it is at higher average elevation than your feet. Thus if there were a particle of uranium lodged in your head, and another in your foot, the one in your head would have emitted more alpha particles over your life (a direct measure of age). This is due to what is called gravitational time dilation. Sticking to special relativity, if you were in deep space and did a lot of activity with your hands, then your hands would be younger than your body.
Oh, that's a relief. I thought you meant something else rather than the time dilation. I understand why the effect occurs then.
durant said:
my body, and any other body that is 'partially-moving' should have its rest frame because that 'allows' the sequence of timelike-events of that body
If you remember that a rest frame is defined as a frame in which a point is at rest (when you hear someone speaking of "the rest frame of an object" they are using a convenient shortcut for the more precise "a frame in which every point of that object is at rest") it's clear that there is no such thing as "the rest frame of a partially moving object".
However, that doesn't affect the time-like ordering of events in any meaningful way. Let's go back to your extended cat. It catches its tail in a door, a nerve impulse travels from its tail to its brain, and it yowls. Look at the world-line of the tip of the tail and of the point in the brain where the signal arrives; draw a slanting line between those two world lines to track the path of the nerve impulse to its brain. Every observer, regardless of their speed and reference frame or anything else, will agree that the tail-in-door event happened before the signal-reached-brain event. No observer will believe that these two events were simultaneous (that is, no observer will believe that the nerve impulse took no time to travel from tail to brain).
All observers will agree about the properties of the worldtube because anything that can be termed a property of the worldtube is an invariant.
Things that are not invariant are not properties of the worldtube but rather relationships between the worldtube and the reference frame. The sequence of causally disconnected events is one such thing. The sequence of causally disconnected events is not a property of the worldtube but a relationship between the worldtube and the observer's reference frame. Thus different observers will disagree about that.
What would happen if the cat was, hypotethically, moving its tail (while the other parts are at relative rest), and changing color as a whole? Would all observers agree on that?
Ok, that's one of the things that I've been seekin' clarification for... Good to know that we're on the same page.
Then don't do things like waste a half-dozen posts explaining why you think that "events" have parts when you have already been informed that they do not and given explanations about the technical meaning of the term "events" as it is used in relativity.
If you do not understand the meaning of a techincal term then ask for clarification, but arguing against basic definitions is not helpful. When you do that you sound like someone with a philosophical agenda rather than someone interested in learning science, an impression furthered by your post about metaphysics.
My opinion is still that the two concepts are related (even more than you think), but I won't insist on it. If you're picture of the world is based solely on measurements and logical positivism, that's okay with me. After all this is a physics forum like you said and all threads should involve a physics judgement of the terms stated. And also, there's a big difference between common sense and metaphysics, so there's no need stating those 'frightening' sentences like 'The relativity destroys your common sense picture' and so on. But as I said, I will adjust, it's my duty as a forum member who seeks opinion from people that are really into this field.
So it's been stated before that the worldtube of the object I described doesn't have a local, or proper time. What if an object was first at rest as a whole, but then changed into a state where it's one part is still at rest, but the other is moving? Does the local time get somehow destroyed, since the object no longer has a specific state of motion as a unity?
durant said:
What would happen if the cat was, hypothethically, moving its tail (while the other parts are at relative rest), and changing color as a whole? Would all observers agree on that?
The moving tail would make the shape of the world tube a bit more complicated, but that doesn't change anything in my post.
The color-change question may be more interesting, but it doesn't have a good answer until you have been more precise about exactly what the color-changing process is.
If you imagine a fairy that can wave a magic wand to cast a spell that causes the the cat to instantaneously change its color across its entire body all at once... You will be able to find an observer for whom at least some of the color change happens before the spell is cast, violating causality. All that proves is that such a magic spell is not possible (look into it carefully and you'll see that the spell would have to travel faster than the speed of light).
If you're thinking about some biochemical process (the way chameleons, anoles, flounder, some frogs can change their color), then something will have to start the process and then send some chemical or electrical signal to each point on the skin to make that point change its color. This is very similar to the door-taill-nerveimpluse-brain scenario. All observers will agree that each point on the skin changes color; this effect always comes after the cause.
If you're thinking about going after the cat with a can of spray paint... Draw the slanting worldline of each individual droplet of paint as it leaves the worldline of the spray can nozzle and intersects the worldline of a point on the skin of the cat.
So to sum-up, despite different parts having different states of motion, all observers must agree on the properties of the worldtube as a whole
Proper time is a property of a path between two points in spacetime - it is the amount of time that an ideal clock would record if it were to move along that path from one point to the other (the points must be time-like separated or no such path exists, of course). There are lots of points in the worldtube, lots of paths between them, but for any given path all observers will agree about the proper time along it. Therefore:
No. Various parts of the object start moving at different times (in a frame in which all parts of the object are initially at rest - that's what "first at rest as a whole" means!), but we still have a perfectly good world tube and a perfectly good proper time between various points in that worldtube.
As has been pointed out, this is a physics forum. How would you design a thought-experiment to measure the proper time that you're asking a question about?
I can certainly imagine two clocks, and comparing their proper times. The clocks might be cesium atoms, at their smallest.
Note though that if the clocks aren't at the same point in space, specifying the details of the comparison process is essential - due to the relativity of simultaneity.
What I can't imagine is the significance of the results. It seems to me that if the clocks read the same, or the clocks read differently, that it won't answer your question.
If you've got questions that can't be settled even in principle by experiment, science can't answer them. My impression is that what you're asking is one of those questions - but since I'm not positive I understand what you're trying to ask, I could be wrong.
If I am wrong, then giving the details of the thought experiment that will actually measure this alleged property will hopefully allow us to move forwards - for instance, it might be something we can calculate the predictions of for you (depending on the complexity).
My personal "picture of the world" is irrelevant (it also is not even remotely logical positivism). This isn't about promoting my viewpoint; it is about following the rules of the forum. I don't get to talk about my personal philosophy here, and you don't get to talk about yours.
Proper time is a characteristic of a worldline. So each of the worldlines in the object's worldtube would have a well-defined proper time, but that would not in general coincide with the proper time of other worldlines in the object.
Geometrically, proper time is the Minkowski "length" of a timelike worldline. Consider an object like a string, with length but no width or depth. Now consider that object rotating about its center with its center at rest. Each point on that object would have a helical worldline. The helixes near the center of rotation would have a different length than the helices near the ends. There is no single "length" that you could give for every worldline, but every worldline has its own well defined length.
Except the fact that no observer could determine what's happening in the worldtube at a particular time, since there is no rest frame. So no observer could say 'in the rest frame of his body, the lower part of his body and the movement of his head happened simultaneously? What did you mean when saying that we have a perfectly good worldtube?
A perfectly good worldtube would be the one which allows a rest frame, so the observers could agree on the orderd of events within the worldtube from the perspective/rest frame of the object itself. The worldtube of a partially moving object would not have that property, as I understand. So the order of events within the worldtube, would vary from frame to frame. Please correct me if I'm wrong in my interpretation.
It is not necessary for there to be a rest frame. Again, the whole point of the principle of relativity is that any inertial frame is as good as any other. Please see my previous comments in post 12.
I agree with you, perhaps creating a sub-forum 'metaphysics of physics/science' would be adequate. :P I know that if I could precisely explain to you, Nugatory, or any other experienced forum member what's on my mind regarding this you would answer me instaneously, but the problem is obviously my description. Sorry if you found my post offensive.
  • #31
But how would you describe a worldtube without a proper time. I know that all frames are equivalent, I had that in mind while writing. It seems obvious that the worldtube of a partially moving object is a combination of the worldtubes of the part that is moving and a part that is not, and they both have their rest frames. The question is, if a worldtube of a partially moving object doesn't have local time, how can we say anything about it in terms of 'fixed order' of temporal events inside it?
  • #32
The order of causally disconnected events is not fixed.
The order of causally connected events is fixed and can be determined in any reference frame.
  • #33
We don't need a rest frame to define proper time. Look carefully at my definition of "proper time" in post 25 - there is no rest frame involved, just a path through spacetime.
And I can completely specify a world tube (and for that matter, any collection of points in space time, whether they form a world tube or not) using just the frame-independent proper time and proper distance.
  • #34
You could define a world tube as a collection (a timelike congruence, to be technical) of worldlines. The nature of a timelike congruence is that one and only one worldline passes through any point of the congruence.
With such a congruence, you can meaningful talk about the proper time of any point in the congruence as being the proper time along the unique worldline passing through that point - at least as long as you define some initial set of points in the congruence that have a proper time of zero.
However, given a worldtube, timelike congruences are not unique - you could specify several different congruences that "cover" some particular worldtube. So there isn't any unique or meaningful way of talking about the proper time in a worldtube without specifying a particular congruence.
  • #35
Nugatory, I apologize, but I still don't understand.
In the first posts on this thread it was written that the worldtube of a partially moving object cannot have its proper time (neither can it have a rest frame), but now you're saying that we can define proper time for any worldtube, even if it's the one I've been mentioning throughout this thread.
I know that you have a valid point, but some posts seem contradictory and I certainly know you're not implying any contradictions, so can you please distinguish the difference? How can this kind of worldtube have a proper time, when it was clearly stated before than only its parts have their own proper time?
  • #36
He didn't say that you can define a unique proper time for a half moving object. He said that you could specify any world tube in terms of invariants like proper time.
Consider specifying the location of your house. You could say something like "my house is at latitude 35 N longitude 100 W" or you could say "my house is on Winding Road 2.37 km from where it intersects with Fast Freeway". The former specifies the location in terms of coordinates, the latter in terms of invariants.
Each event in a world tube can be located in terms of invariants. That is completely independent of the fact that not all worldlines have the same length.
  • #37
Back to post #25 in this thread:
"Proper time" is a property of the path between two points in spacetime and the path between them. It's not something that you "define for a worldtube", and it's not something that a worldtube "has". So there's no contradiction when everyone is telling you that a partially moving object doesn't have "proper time".
I have a nagging suspicion that you are confusing proper time with the notion of simultaneity, thinking that proper time is somehow related to the way that we can speak of "the cat's nose and the cat's tail right at this moment".
  • #38
An analogy: two people are walking along a road. Laura walks on the left side of the road. Rob walks on the right side. Whenever they come to a curve in the road, the one on the outside of the curve has to walk further than the one on the inside of the curve. So by the time they get to the end of the road, one is likely to have walked a little further than the other. You can't accurately specify a precise length of the road, because one side of the road is a little longer than the other side.
The effect could be even worse if you imagine a weird road where one side of the road is straight and the other side is wiggly.
In this analogy, "length" is analogous to proper time.
  • #39
I'd like to point out, quickly, that relativity is just space-time geometry.
And, going back to Euclidean geometry as presented in high school, the axiomatic elements of geometry are points and lines.
It's pretty much the same for space-time geometry, aka relativity.
So the situation as I see it is that SR is space-time geometry, defined with points (which we call events) and lines (which we call worldlines). And the OP is obsessed with tubes for some reason, and not listening when we try to explain the axioms of geometry in terms of points (events) and lines (worldlines), which is how the textbooks actually present them, and keeps asking about "tubes".
It's not like tubes are totally outside the realm of geometry - it's just that they're not a good way to learn it, they aren't the axiomatic elements of geometry.
It also doesn't seem to be helping to point out that tubes can be defined in terms of lines.
Anyway, this may be my last post on this thread for a while, I'm feeling a bit burnt out.
  • #40
As I've red in articles about SR, time is local. So the basic impression is that all the person stages are connected, despite the motion of some parts and the rest of others. In this thread it has been stated that only parts with a specific state of motion can have proper time, so is it meaningless to talk about person stages (that all observers will agree upon) when only parts have well-defined stages, and their combination gives us the worldtube.
  • #41
Time is what a clock measures. A clock, of necessity, must be made out of parts that take up some volume of space. And yet we never bother to show the spatial extent of a clock. Rather we conceptualize it as having no spatial extent whatsoever. That's because we are lazy and because we assume that everyone knows that we are taking all kinds of shortcuts to make things manageable when we are depicting a situation or a scenario in which we are trying to teach someone the basics of Special Relativity.
So when we refer to the Proper Time of a clock at a particular location or following a particular trajectory, we are taking shortcuts because it really has multiple Proper Times at different locations on the clock itself. In its own rest frame, assuming that it is inertial and never accelerates, all the Proper Times can be considered synchronized, although technically speaking, that is impossible to do but we can still conceptualize it. Then when we transform this clock into another inertial frame moving with respect to the first one, the different parts of the clock are no longer synchronized. But nobody cares because we pretend that the clock occupies zero space and we don't want to spend the rest of our lives embroiled in the nitty gritty details that would more closely correspond to reality but would not add anything to our understanding.
So it would make a whole lot more sense and be a whole lot easier for you to focus on the parts of a simple light clock which consists of just two reflectors and an impulse of light bouncing between them along with a magic counter on one of the reflectors that marks off the Proper Time of the light clock while ignoring the Proper Time of the other reflector and the Proper Times of the infinite number of locations between the two reflectors and to see how this simple scenario plays out in different reference frames instead of jumping first into the Proper Times of a person moving his head around with respect to the rest of his body.
Understand this: if you want to deal with all the details of a human body articulating in a random manner, it can be done. You can define each point on the body in terms of its coordinate location in some inertial frame at a starting coordinate time of zero and assign a Proper Time of zero to each of these points and then define any kind of coordinate motion to the different parts as a function of Coordinate Time and this will enable you to determine the Proper Times of all these parts as a function of the Coordinate Time of your inertial frame. Then if you want, you can transform all the coordinates of all these events into the coordinates of any other inertial frame moving with respect to your first one and get a whole new set of coordinate values for each event. And then you can do it again for a thousand other inertial reference frames, each one moving in at a different speed and/or direction with respect to the first one.
Why do you want to do this? Why isn't it enough to treat a simple problem so that you can grasp the concepts of Special Relativity and be done with it? All you are doing with these complex scenarios is compounding the process without increasing any understanding.
  • #42
Because it isn't that simple for me... I'm a beginner in this and these complex scenarios aren't really that complex, they are like everyday examples. And, sincerely, it's killing me knowing that when I write something nobody will approve it, in fact I cannot get a straight-forward answer to the stuff that's been bothering me.
I know that we can divide a human body into parts with their own coordinate systems, but why can't we then speak of the human body in terms of a space-time worm, as it is called in metaphysics of time. A 4 dimensional object (worldtube) which stages are fixed, and all observers will agree on the sequence of events or person stages on that object's worldtube? Seems to me that we can only speak of the stages of the head, stages of the hands and so on, but we can't 'find' a unique state of body which all observers will agree upon.
  • #43
According to the posts here, when an object has a state of motion as a unity, it has a local time, but if it changes to the state where one part is moving and another is at rest, then the local time of the object no longer exists, but there still exist local times of the parts of that worldtube.
  • #44
I'll tell you what's bothering me: ten minutes after I make a rather lengthy post, you have posted a reply. That tells me you haven't read and studied my post. You haven't had time. And the evidence follows:
I never said we can divide a human body into parts with their own coordinate systems. I said we "can define each point on the body in terms of its coordinate location in some inertial frame". One frame for all, not one frame for each part. In other words: ONE FRAME. Got it? ONE FRAME. ONE FRAME. ONE FRAME.
This is evidence that even though you are given straight-forward answers to your questions, you are not taking the time to read and study them.
All observers will never agree on anything unless it is precisely spelled out to begin with. I have given you a straight-forward answer to this question but you fly right past it and claim that I haven't answered your question.
Once again: Start with a single inertial reference frame. Start at coordinate time zero. I would suggest that you use units of feet and nanoseconds and define the speed of light to be one foot per nanosecond. Provide the coordinate locations of every part of the human body you want to consider. Make a big long list including each joint of each bone and each part of each internal organ and each part of the surface of the body and each hair follicle along with the extended shape of each hair to its end point(s). Then make another list for each item on the first list describing how you want it to move in three dimensions as a function of the coordinate time (which includes those at rest). You can make these lists as long or as short as you want. Now you can place observers anywhere you want moving any way you want in this same inertial reference frame and, if you are making a spacetime diagram, you can draw in light rays going from each event (which includes each moment in time) going to each observer and you'll have the answer to your question of what any observer will see of this human. If you don't make a drawing, you will have to mathematically determine how long it takes for the image of each event to reach each remote observer.
Now different observers will see different things at different times according to their own particular location and motion and therefore as a function of their own Proper Time. But they will all agree on what happens to the different parts of the human they are observing as function of the different Proper Times of all the different parts. There is not one Proper Time that applies to the human as a whole. In fact, there's not even a meaningful "average" Proper Time that applies to the human.
Now you can transform this entire scenario, including the complicated human and all the observers into any other Inertial Reference Frame moving with respect to the first one and you will get a new set of Coordinate Times and Coordinate Locations complete with the light rays going from each event of the complicated human to each observer and you will show that they still see exactly the same things according to their own Proper Times in terms of the Proper Times of the parts of the human that was depicted in the first Inertial Reference Frame.
Now I have repeated this same answer again for you. Are you going to say that I have not given you a straight-forward answer to your question? If you don't understand my answer, please explain where the problem is.
  • #45
The problem is that you're describing something that has nothing to do with what I asked. You are describing a relationship between a coordinate system and a specific object, in this case some part of the human body. I was referring to the fact that timelike events in SR are invariant, that is, all observers will agree of them. So in the case of a human, I don't understand how we can't define a unique state of its body 'experienced' by its body alone, as a whole. It's more of a thought experiment. Please explain the previous comment that I wrote, this one:
"According to the posts here, when an object has a state of motion as a unity, it has a local time, but if it changes to the state where one part is moving and another is at rest, then the local time of the object no longer exists, but there still exist local times of the parts of that worldtube."
  • #46
If by "local time" you mean "Proper Time", then you should say "Proper Time". If you don't mean "Proper Time" then what do you mean by "local time"?
As I said in post #41, even the "Proper Time" of a clock is a shortcut and we use it because we are lazy. In SR scenarios, we talk about people traveling at high speed in rocket ships but we never worry about the details of their motion within the rocket ship because it detracts from the salient point that we want to make.
In the case of a human being moving his head but not his body, there is no way to actually measure the difference in Proper Time between them no matter how much he wags his head around. But you could calculate the difference if you define the exact motion you want to consider and you have a calculator with enough precision. Perhaps it would be useful if you would provide these details for a scenario you find interesting. Let's assume the human's body is at rest in the negative portion of a coordinate system along the z-axis (all the parts of his body have negative coordinates in the z-axis). Then let's say that his head is one foot high and he nods his head back and forth along the x-axis a total of one foot (plus and minus six inches). And let's say that he stretches his neck as he does this so that the top of his head only has motion along the x-axis (the y- and z-axis parameters are constant). And let's say that the speed of the top of his head is constant with instant reversal of the motion. Now describe how many times per second you want him to complete each cycle of this motion and for how long you want this to go on for and see if you can calculate the difference in the aging of his head relative to his body, in the rest frame of his body. It's really a very simple problem. Can you do it?
  • #47
Unfortunately, I can't. I'm weak in this kind of mathemathics...
I don't understand why do you state it's so simple and then throw out all the possible coordinates and random lenghts. You clearly don't understand that I don't posses the same level of knowledge as you and things that look simple to you are extremely complicated to me.
I asked you a question and again you're not giving me an answer which eliminates all the calculating. If the things exist in a way you believe they do, explain it to me in a concrete way. You're behaving like I would if I was explaining integrals and derivations to a 5-year old.
  • #48
How did you get that from what I wrote? I said all the parts of the human body and all the remote observers are described according to a single Inertial Reference Frame and its coordinate system.
Events are not categorized as being timelike. (That term applies to certain pairs of events.) Where did you get that idea from? You should think of an event as having coordinates and these coordinates can be different in different coordinate systems, that is, in different Inertial Reference Frames. It is the Proper Time of an object/clock that can have different coordinate times (and locations) in different IRF's but they all will agree on the Proper Time of that particular object/clock. You can have two objects/clocks with different Proper Times colocated at the same location and at the same time so that they are associated with the same event.
So I'm having real trouble understanding your statement that timelike events in SR are invariant. The best I can surmise is that you mean all observers will agree on the Proper Time of a clock at all events of that clock. But didn't I make that very clear in my previous long posts? Yes, I did. I described how not only will all remote observers agree on the Proper Times of all the parts of the human body, even though they see them at different later times, they still will agree when we transform the entire scenario into a different IRF. Didn't I say that? Isn't that exactly what you are concerned about? So I did in fact address the issue you have in mind, you just are reading too fast and not studying what I write to take it in.
As I have repeatedly said, you can define any state of a human's body to any degree of complexity that you want but if you find it significant to take into account the nanoseconds of difference between different parts of the body then go ahead. But if by "experienced", you mean something that a human can actually detect within his body, then forget it. If we could detect relativistic effects within our own bodies, it wouldn't have been many thousands of years of human history before relativistic issues became known and it was only because of advances in technological instruments, not human bodies, that permitted precise enough measurements that lead to the recognition relativity and the development of the theory of Special Relativity.
I already did in the previous post. I'll see if it was adequate as I'm guessing you have probably already responded.
  • #49
Then why do you say that a partially moving object doesn't have a proper time?
  • #50
For the same reason that I just said that "You can have two objects/clocks with different Proper Times colocated at the same location and at the same time so that they are associated with the same event. Each object/clock that has a different history of motion will have a different accumulation of Proper Time. If you have what you are calling "a partially moving object" you really mean two or more independent objects with different histories of motion and therefore can have different accumulations of Proper Time.
So you could have a person slap himself on the head and while his hand is in motion, it accumulates less Proper Time than his head does during each slap. So now if you ask the question, what is the Proper Time of this person, it will have at least two answers, one for his hand and one for his body and head. (The different parts of his arm will have multiple other Proper Times because they are moving at different speeds.) Lot's of different answers for the different parts of his body because of their different histories of motion.
Do you think there can possibly be one answer to the question of the Proper Time of a partially moving object?
