Properties of Line Integrals question
38 replies · 6K views · last reply
WMDhamnekar
MHB
TL;DR
Let ##f(x,y) =\frac{-y}{x^2+y^2} \hat{i} + \frac{x}{x^2+y^2}\hat{j}## for all ## (x,y) \not= (0,0),## and ##C: x= \cos {(t)}, y = \sin{(t)} , 0\leq t \leq 2\pi.##
(a) Show that ##f = \nabla F,## for ##F(x,y)= \tan^{-1}{\bigg(\frac{y}{x}\bigg)}##
(b)Show that ## \displaystyle\oint_C f\cdot dr = 2\pi.## Does this contradict the following corollary 4.6 ? If yes, explain, If no, explain.
Printed text of Corollary 4.6: If a vector field f has a potential in a region R, then the closed line integral of f dot dr over a closed curve C in R equals 0, i.e. the closed integral of grad F dot dr equals 0 for any real-valued function F(x, y).
I don't have any idea to answer these questions. I am working on it by searching the reference books where similar questions have been solved by authors. Meanwhile, any member of Physics Forums may help me in answering these questions.
Hint for a) ## \vec f(x,y) = f_x (x,y) \hat i + f_y (x,y) \hat j = \dfrac{\partial F(x,y)}{\partial x} \hat i + \dfrac{\partial F(x,y)}{\partial y} \hat j ##
It is just a matter of using the definition of gradient. Now one just have to do some partial derivatives and some algebra.
b) Can you draw in a x-y coordinate system the curve C? Is the given F(x,y) defined for all points on and inside this curve?
Answer to (a) ##f(x,y) = \frac{-y}{x^2+y^2}\hat{i} + \frac{x}{x^2+y^2}\hat{j}## has a potential ##F(x,y) =\arctan{y/x}##
Now, ##\nabla F = \frac{x}{x^2+y^2}\hat{j}= f(x,y) \because \frac{-y}{x^2+y^2}\hat{i} =0 ## for y= sin(t) where 0≤t ≤2π
Answer to (b) ##\displaystyle\oint_C f\cdot dr = \displaystyle\int_0^{2\pi} 1dt= 2\pi##. The answer is nonzero. So it contradicts with the given corollary 4.6.
Are my both answers correct?
WMDhamnekar said:
In my opinion,
Math is not about opinions.
Your result for b) does not contradict corollary 4.6, look at what conditions must be fulfilled in order for that corollary to apply. Are those conditions met in this problem? Does an equilateral triangle contradict Pythagoras theorem?
For a) you have not done anything I told you to do, you need to evaulate the partial derivatives of F(x,y) and show that those indeed match the given components of your function f(x,y).
Answer to (a)
##\frac{\partial{\arctan{(\frac{y}{x})}}}{\partial{x}}= \frac{-y}{x^2+y^2}, \frac{\partial{\arctan{(\frac{y}{x})}}}{\partial{y}}= \frac{x}{x^2+y^2}##
So, we can say ##f=\nabla F ## for F(x,y) = tan-1(y/x)
Answer to (b) ##\displaystyle\oint_C f \cdot dr = 2\pi ## f(x,y) is valid for all (x,y ) ≠ (0,0).
Now , In the following cases -sin(t) = 0, when t =0, π, 2π. cos(t) =0 when t=π/2, 3π/2.
Now, how to use that information here?
I am unable to graph this f(x,y) in 2D? If you show me how does it look in 2d, It would be better to grasp your answer.
I wrote that you should graph the curve C, not f(x,y)...
Is F(x,y) defined for all points on the curve C and inside the curve C?
Look carefully at the expression for F(x,y) - what x and y values makes it not being defined?
Corollary 4.6 from a calculus text: if a vector field f has a potential in a region R, then the line integral of f dot dr over a closed curve C in R is 0, i.e. the line integral of grad F dot dr is 0 for any real-valued function F(x, y). Red underlines mark parts of the statement.
F(x,y)= tan-1(y/x) is undefined for (x,y)=(0,0). So, How can we say it doesn't contradict corollary 4.6?
There are more points for which it is not defined.
What are the requirements for corollary 4.6?
Please answer this question: Does an equilateral triangle contradict Pythagoras theorem?
Equilateral triangle doesn't contradict Pythagoras theorem.
The requirement of corollary 4.6 is ##\displaystyle\oint_C \nabla F \cdot dr =0 ## which is not fulfilled in our case.
So, you mean to say, that's why it doesn't contradict the given corollary. If that logic is correct, Okay. I agrre with you.
Author also answered what you answered. Thanks.
f(x,y) does not have a potential for all the points in the region which C encloses, because F(x,y) is not defined when x = 0 and x=0 is indeed happening inside (and on) C. Therefore, the corollary does not apply. It is not contradicted, because its requirements are not fulfilled so there is nothing to be contradicted.
I think the shaded region(drawn red lines) in the following graph is the line integral intended in this question.
Hand-drawn diagram of x and y axes with a red-hatched annular region centred at the origin, between a small inner circle and a larger outer circle.
Nope, the parametric curve defined by x = cos(t) and y = sin(t) where 0 ≤ t≤ 2π you must know!
Try to plot it for some values of t like 0, π/4, π/2, 3π/4, and so on...
Do you mean to say these curves?
y1(x)=cos(x)
Calculator screen plotting two sinusoidal curves on the same axes, one crossing the origin and one peaking at the y-axis, with tick marks along both axes.
y2(x)=sin(x)
Calculator screen plotting a sine-like wave over x-axis from about -2π to 2π with a y-axis at center, with menu labels Zoom, (X,Y), TRACE, Fcn, Edit, CANCL below.
Simultaneous plottings of both the graphs below:
Calculator screen plotting two curves together, a sine and a cosine wave of the same amplitude, crossing each other across the x-axis.
No plot the points (x,y) for some values of t in the range from 0 to 2π, where x = cos t and y = sin t ...
I'll give you a hint, here are the points for t = π/4 and t = π/4
Coordinate grid with x and y axes from -1 to 1 showing a single blue point at (0, 1) and another at approximately (0.71, 0.71).
How come you are doing line-integrals but don't know the basics of parametric curves?
Do you mean the following graph?
Screenshot of a parametric curve plot in a graphing application showing x = cos u and y = sin u, with a magenta right-hand arc on a grid with axes from -1 to 1, and a table of u, X and Y values alongside.
drmalawi said:
What does the entire parametric curve C look like?
Have you seen my post #15? In the graph given in #15 ,t is substituted by u.
the parameter values are not between 0 and 2π hence the entire curve C is not plotted
In the following graph, is the entire curve C plotted?
Screenshot of a parametric plotting tool with x = cos u and y = sin u, showing a quarter-circle arc in magenta from the x-axis to the y-axis on a 2D grid, with a table of u, X and Y values alongside.
WMDhamnekar said:
u(t) ranges from 0 to 2π, so x = cos (u) will also range from -1 to 1 and y = sin(u) will also range from -1 to 1.
Now you got to be kidding me.
What if t = 3π/4? Then x<0 but y>0
I think you need to practice basics first.
Another way of analyzing that parametric curve is to see that x2 + y2 = 1 for all values of t. What kind of curve satisfies the equation x2 + y2 = 1?
I am a novice in using the graphing calculator. I can plot it manually, but it is time consuming and cumbersome exercise. Thanks for helping me to answer this question.
You really need to know how these curves work, rely on brain not on calculator.
here I did it for you with geogebra using the slider function
Dotted plot of a closed circle of radius 1 centred at the origin, with x-axis and y-axis marked at -1, -0.5, 0.5 and 1 and grid lines.
now having tighter values of t
Plot of a unit circle centred at the origin on x and y axes with grid lines, marked at 0.5 and -0.5 on each axis and at -1 and 1 on the x axis.
looks to me its a circle with radius 1 and center at the origin. Wow that's so cool! But hey, the equation for such circle is x2 + y2 = 1, which is indeed satisfied for x = cos t and y = sin t
Bonus question, if t was ranging from 0 to π then the curve would become this:
Graph of the upper half of the unit circle, a semicircular arc from (-1, 0) to (1, 0) through (0, 1), on axes labelled from -1 to 1.
this is becase we will never hit any negative y-values for this range of t, so the curve in this case is not closed, it is a semi-circle.
The graph you drawn is same which was posted in #11. But, I didn't write the x and y coordinates in that graph. It was the rough sketch I drawn(#11). Sorry, if you have any trouble while helping me to answer this question.
WMDhamnekar said:
Hi,
If the above given graph is the line integral, how would you draw a line integral for the circle drawn by you?
That's what I did in #11 though it looks like the annulus as you said
I only asked what the curve C looked like. You have to read things carefully.
Text reading: b) Can you draw in a x-y coordinate system the curve C? Is the given F(x,y) defined for all points on and inside this curve?
and your function f(x,y) is a VECTOR function, it takes a coordinate as input and spits out a vector.
How to prove ∮C f∙ dr =0 in the example given below:
Figure 4.3.3 showing the annulus R between the unit circle C1 (counterclockwise) and the inner circle C2 of radius 1/2 (clockwise), shaded grey, with axes marked 1 and 1/2.
That result depends on what region R you are considering.Here, first the origin is removed so that Greens theorem does not apply. R is all points (x,y) s.t. 0 < x2 + y2 ≤ 1. Thus the curve C: x = cos t, y = sin t, 0 ≤ t ≤ 2π does not enclose the entire region R. C covers more than R. This means that Greens theorem is not applicable.
Solid grey filled disc with a black outline and a small white dot at its centre.
Then they change the region so that there is an annulus instead, and now Greens theorem applies.
The problem as you originallly phrased it, did not mention any region whatsoever, only a curve. And when you do so, then it is implied that the region R is everything on and inside of C.
You have to pay attention to these little details, they are crucial.
Author has not proved in this example, how ∮Cf∙dr = ∮C1f∙dr1 + ∮C2 f∙dr2 = 0.
I want to know how can we prove it?
( I think author left this topic for the readers to prove themselves as a homework exercise)
