Properties of Roots in Univariate Polynomial of Degree n
The discussion focuses on proving that for a univariate polynomial of degree n, the absolute value of its root r satisfies the inequality |r| ≤ max(1, Σ |a_i/a_0|). Participants explore the implications of setting a_0 = 1 to simplify the proof and suggest testing specific cases for n=1 and n=2 to understand the behavior of roots. There is a debate about the correctness of applying the inequality and whether certain assumptions lead to contradictions. The conversation emphasizes the use of the triangle inequality and the significance of the maximum function in the context of polynomial roots. Overall, the participants are working towards clarifying the proof strategy for the stated inequality.
knowLittle
1. Let ##p(x) = a_{0} x^{n} + a_{1} x^{n−1} + ... + a_{n} , a_{0} \neq 0 ##be an univariate polynomial of degree n.
Let r be its root, i.e. p(r) = 0. Prove that
## |r| \leq max(1, \Sigma_{1 \leq i \leq n} | \dfrac{a_{i} }{ a_{0} } | )##
Is it always true that?
## |r| \leq \Sigma_{1 \leq i \leq n} | \dfrac{a_{i} }{ a_{0} } | )##
##ar + br^{2} =0 ##
## r(a+br)=0 ##
## r=0 & r = -a/b##
The last equation satisfies what they state but I don't know how to proceed?
Any help?
##ar + br^{2} =0 ##
## r(a+br)=0 ##
## r=0 & r = -a/b##
Any help?
For almost all such polynomial probs there is no loss of generality in making a0 = 1 and then you don't have that denominator in the expression.
Not sure I know now to proceed either but since they bring in 1 as a case of maxima, it is suggestive when you put r = 1 perhaps.
I don't follow what you are saying with your relevant equations but when you can't see how to do it in general it is certainly good to try with n=1 and 2.
I sort of proved it by contradiction.
Let's say that
## p(x)= ax^{2}+bx=0##
## 0=x(ax+b), \text{ then the roots are }r_{1}=0 \text{, } r_{2}=\dfrac{-b}{a}##
## |r| \geq \dfrac{a+b}{a} \\##
## | r_{2}|=| \dfrac{-b}{a}| \geq | \dfrac{ a+b}{a}| \text{, will never be true.}##
Let's say that
That I think is not right, you have misunderstood the formula in the original problem. The Ʃ subscript contains a 1≤ not a 0 ≤. The theorem then is rather trivially true for the first degree case with the ≤ it was required to prove reducing to = . Also your factor x seems an irrelevancy. But there is maybe the germ of an argument.
As I said you avoid something unnecessary if you make, without loss of generality, a0 = 1. So then the question becomes:
Let ##p(x) = x^{n} + a_{1} x^{n−1} + ... + a_{n} , ##
then prove
|r| ≤ max( 1, | a1 + a2 +... + an| ).
I think my previous idea leads there but maybe extending what you were trying does too.
Here's another hint. Since you have the 1 in the max, it's trivial if |r|<=1. So you only have to do some work for the case |r|>=1. You'll want to use the triangle inequality.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
