Prove/Disprove: p(a∩b) ≤ q^2 with a,b Independant
The discussion revolves around the probability statement concerning two events, a and b, where the probabilities of both events are equal to q. Participants are tasked with proving or disproving the assertion that p(a∩b) ≤ q², particularly under the condition that a and b are independent events.
  • Mixed
  • Some participants attempt to calculate p(a∩b) under the assumption of independence, leading to the conclusion that p(a∩b) = q². Others question whether this holds true for all possible values of q and explore the implications of dependency between events.
Participants are actively exploring various scenarios, including cases where a and b are independent versus dependent. There is recognition that the statement can be disproven by providing counterexamples, and some participants are considering specific values for q to test the assertion.
Participants note the importance of understanding the relationship between events a and b, as well as the implications of their independence or dependence on the validity of the original statement. There is also mention of previous threads and attempts that may have contributed to confusion in notation and reasoning.
rangatudugala
Prove or disprove the following statement:
If p(a)=p(b)=q then p(a∩b)≤q2
We know nothing know about event a , b.
I tried this but don't know correct or not
Can some one help me
let a, b are independent event
0<q<1
then p(a∩b) = p(a) p(b) = q*q = q^2
[/B]
RUber said:
Did you give up on the other thread? https://www.physicsforums.com/threads/statistical-physics.827663/
I suggest you disprove the statement.
If a = b, then P(a) = P(b) =q, so your condition is met.
What is P(a∩b)?
Is P(a∩b) ≤ q2 for all possible values of q?
previous thread I used confusing notation (It was my 1st attempt )
I tried but no idea feel something missing
0<q<1
You won't prove that the statement is true or untrue by assuming that a and b are independent.
If a and b are independent, then the statement is true.
If a and b are not independent, you still don't know.
You either have to prove that
for all a and b such that p(a) = p(b) = q the statement is true
or
there exists at least one pair of a and b such that p(a) = p(b) = q AND the statement is false.
Let a = b and q = .5.
What do you find out?
or
Okay..
then p(a∩b) = p(a) p(b) =0.5*0.5 = 0.25
rangatudugala said:
Okay..
is there any other answer ??
rangatudugala said:
Okay..
No, that only works if they are independent. As RUber says, you need to think about two events that have some dependency. What's the most dependent you can make two events? (When two events have some dependency, knowing the outcome of one gives you information about the likely outcome of the other.)
p(a∩b) = p(a) + p(b) - p(ab)Then how to get p(ab)??
rangatudugala said:
Okay..
What is p(a ∩ a)?
RUber said:
What is p(a ∩ a)?
RUber said:
What is p(a ∩ a)?
p(a ∩ a) = 0.5
rangatudugala said:
p(a ∩ a) = 0.5
isnt it?
Right. Is that less than or equal to q^2?
Is p(a)=p(a) =q?
Is p(a)=p(a) =q?
its greater than q^2
p(a)=p(a) =q yes
So then...?
RUber said:
So then...?
1/ let a, b are independent event
0<q<1
2/ a, b not independent event
0<q<1
then p(a∩a) = q >= q^2but why we going to calculate p(a∩a)??
question was p(a∩b) =< q^2 know i confused again.. Am I missed step ?
Okay, then let a and b be two separate events, that are highly correlated.
Let a = Is a student
Let b = Goes to school
Essentially, these are the same thing as saying a = b.
The reason we are doing this is because nothing in the statement you are trying to prove or disprove says we can't. If the statement is true, it must hold for all choices of a and b, including a = b. So if it doesn't hold for a = b, then it is disproved.
To disprove the statement, you don't have to show that it is always wrong, just that it could be wrong.
The fact is that the statement is true only when a and b are either independent or less likely to occur together than on their own.
So, like I have been saying. Use a = b and 0<q<1. Show that the example fits the assumptions for your statement (if ... ), then show that the outcome is false (then...) . This is how you disprove an if, then statement.
Big Thanks Sir...
Now I got the Point
we don't know anything about event a & b so we can do both prove & disprove using "if statements.
Thank you sir again.
Big sorry if I bothered to you so much.. :)
You can only disprove the statement as written.
You can show that in some cases, p(a) = p(b)=q and p(a ∩ b) ≤ q^2, but you can also show that in some cases p(a) = p(b)=q and p(a ∩ b) > q^2.
That means that the statement as a whole is proved false by counterexample.
  • · Replies 19 ·
  • · Replies 20 ·
