Prove eigenvalues of the derivatives of Legendre polynomials >= 0
11 replies · 4K views
lriuui0x0
For a particular ##\lambda##, we know Legendre polynomials are the solutions to
(1-x^2)\frac{d^2P}{dx^2} - 2x\frac{dP}{dx} + \lambda P = 0
We can show by induction that the k-th derivative of ##P## satisfies
(1-x^2)\frac{d^2P^{(k)}}{dx^2} - 2(k+1)x\frac{dP^{(k)}}{dx} + \lambda_k P^{(k)} = 0
where ##\lambda_k## is fixed once ##\lambda## is fixed.
We want to show if ##P^{(k)}## is not identically zero, then ##\lambda_k \ge 0##.
Parseval's identity?
The problem has a hint about finding a relationship between ##\int_{-1}^1 (P^{(k+1)}(x))^2 f(x) dx## and ##\int_{-1}^1 (P^{(k)}(x))^2 g(x) dx## for suitable ##f, g##. It looks they're the weighting functions in the Sturm-Liouville theory and we may be able to make use of Parseval's identity? However I'm not sure how we exactly do this. I have recast the differential equation to the self-adjoint eigenvalue problem form:
\frac{d}{dx}((1-x^2)^{k+1}\frac{dP^{(k)}}{dx}) = -\lambda_k(1-x^2)^kP^{(k)}
on Phys.org
fresh_42 said:
Can you use an explicit formula of the Legendre Polynomials, e.g. Rodrigues formula? What are ##f(x)## and ##g(x)##?
The hint looks like Wirtinger’s inequality for periodic functions.
Maybe we're able to do it using Rodrigues formula but I don't think that's the original intention of the problem. I'd be interested in ways to prove this without explicitly knowing the solution of the Legendre polynomials.
So we are stuck with a Sturm-Liouville equation.
I'm not an expert in functional analysis, but Wikipedia says, that for the given equation ##-(p\psi')'+q\psi=\lambda \omega \psi## one introduces the linear operator ##\mathcal{L}=\dfrac{1}{\omega }\left(-\dfrac{d}{dx}p\dfrac{d}{dx}+q\right)## and applies spectral theory on ##\mathcal{L}\psi=\lambda \psi .##
I also found an asymptotic behavior for the ##\lambda_k## (Weyl asymptotic)
\lambda_k=\pi^2\left(\int_a^b\sqrt{\dfrac{\omega(x)}{p(x)}}\,dx\right)^{-2}k^2+O(k)
Looks as if you can prove Weyl then you can prove your problem.
Emmm... I don't feel Weyl asymptotic is the expected solution either...
The ##f(x)## and ##g(x)## are the functions you're supposed to find. I'm guessing these functions are the weighting function for the weighted inner product. So given the self-adjoint operator, I guess maybe we can try to to find the relationship of the following two integrals:
\begin{aligned}
\int_{-1}^1 [P^{(k)}(x)]^2 (1-x^2)^k dx \\
\int_{-1}^1 [P^{(k+1)}(x)]^2 (1-x^2)^{k+1} dx \\
\end{aligned}
But I don't know how these integrals are related to ##\lambda_k## and ##\lambda_{k+1}##.
Also note that if we fix a particular ##\lambda##, then we also fix ##\lambda_k = \lambda -k-k^2##
I found the following theorem (with proof but wrong language):
For the eigenvalues ##\lambda ## of the Sturm-Liouville problems
\mathcal{L}P=-(f \cdot P')'+g\cdot P = \lambda \cdot \omega \cdot P
over the interval ##[-1,1]## with ##f(x)>0## and ##\omega (x)>0## for all ##x\in (-1,1)## with the specific initial values
P(-1)=0\, , \,P(1)=0\quad \text{(Dirichlet)}\quad\text{ or }\quad P'(-1)=0\, , \,P'(1)=0\quad \text{(Neumann)}
or even ##P(-1)=0=P'(1)## or ##P'(-1)=0=P(1)## we have
\lambda \geq \min_{x\in [-1,1]}\dfrac{g(x)}{\omega(x)}
The proof simply considers
\dfrac{\langle P,\mathcal{L}P \rangle}{\langle P,P \rangle_\omega} =\dfrac{\langle P,\lambda\cdot\omega \cdot P \rangle}{\langle P,P \rangle_\omega} =\lambda
and integrates it.
fresh_42 said:
Why is ##k=0## excluded, e.g. for ##\lambda =-1##?
##k=0## is not excluded? It simply degenerates to the normal Legendre equation in that case? I don't think we will have ##\lambda = -1## as the eigenvalue. Since we know the solution should be the Legendre polynomial and it must be ##\lambda = n(n+1)##.
and integrates it.
Thanks for the help! I also got the solution, though much more noisy :) As you said, we basically transform the self-adjoint differential equation:
\begin{aligned}
\frac{d}{dx}((1-x^2)^{k+1}\frac{d}{dx}P^{(k)}) &= -\lambda_k(1-x^2)^kP^{(k)} \\
\frac{d}{dx}((1-x^2)^{k+1}\frac{d}{dx}P^{(k)})P^{(k)} &= -\lambda_k(1-x^2)^k[P^{(k)}]^2 \\
\int_{-1}^1 \frac{d}{dx}((1-x^2)^{k+1}\frac{d}{dx}P^{(k)})P^{(k)}dx &= -\lambda_k \int_{-1}^1(1-x^2)^k[P^{(k)}]^2 dx \\
\biggl[(1-x^2)^{k+1}\frac{d}{dx}P^{(k)}P^{(k)}\biggr]_{-1}^1 - \int_{-1}^1(1-x^2)^{k+1}[\frac{d}{dx}P^{(k)}]^2 dx &=- \lambda_k \int_{-1}^1(1-x^2)^k[P^{(k)}]^2 dx \\
\lambda_k \int_{-1}^1(1-x^2)^k[P^{(k)}]^2 dx &= \int_{-1}^1(1-x^2)^{k+1}[\frac{d}{dx}P^{(k)}]^2 dx
\end{aligned}
Then we have ##\lambda_k \ge 0## given ##P^{(k)}## is not identically zero.
I guess the lesson here is in your compact equation:
\lambda = \frac{\langle P, \mathcal{L}P\rangle}{\langle P, P\rangle_w}
Neither do I. But if you set ##k=0## in your equation, then the first equation is the result. But you did not specify ##\lambda =\lambda_0,## so negative values would be allowed, in contrast to your claim that ##\lambda_k\geq 0.## I guess ##\lambda ## isn't as arbitrary as you said.
Yeah that's true. By fixing ##\lambda## we still need to make the original diff equation hold, which means ##\lambda## cannot be arbitrary.
