Prove False: n\geq a\Rightarrow n!\geq a^n
  • Context: Graduate
  • Thread starter Thread starter 3.1415926535
    Induction
The discussion revolves around the statement "n ≥ a ⇒ n! ≥ a^n" for natural numbers n (excluding zero) and the attempt to prove its falsehood using mathematical induction. Participants explore the validity of the induction hypothesis and the implications of varying values of a.
  • One participant attempts to prove the statement false using induction, starting with n=1 and assuming the hypothesis holds for n, then trying to extend it to n+1.
  • Another participant points out that the induction hypothesis used is incorrect, suggesting that it should focus on a specific integer n rather than all integers.
  • A similar correction is reiterated by another participant, emphasizing the need for a proper induction hypothesis.
  • One participant humorously notes that clerical errors can lead to significant misunderstandings in mathematical proofs.
  • Another participant highlights that the assumption "n+1 ≥ a" does not necessarily imply "n ≥ a," which is a critical flaw in the reasoning presented.
  • It is noted that the values of a can change with n, which complicates the application of induction, as it typically requires a constant a.
Participants generally disagree on the validity of the initial proof attempt and the correct formulation of the induction hypothesis. Multiple competing views on the approach to the problem remain unresolved.
The discussion reveals limitations in the assumptions made regarding the relationship between n and a, as well as the implications of varying a with respect to n in the context of induction.
3.1415926535
I will prove the false statement, that n\geq a\Rightarrow n!\geq a^n, n\in \mathbb{N}-\left \{ 0 \right \} with induction
For n=1 1\geq a\Rightarrow 1!\geq a^1\Rightarrow 1 \geq a which is true.
Suppose that n\geq a\Rightarrow n!\geq a^n, n\in \mathbb{N}-\left \{ 0 \right \}
Then,
n\geq a\Rightarrow (n+1)!\geq nn!\geq aa^n=a^{n+1} which yields that n+1\geq a\Rightarrow(n+1)!\geq a^{n+1}
Therefore, n\geq a\Rightarrow n!\geq a^n
But for n=3,a=2 using the inequality we just proved 3\geq 2\Rightarrow3!\geq 2^3\Leftrightarrow 6\geq 8 Impossible!. Where is my mistake?
[EDIT] Don't bother answering. I have highlighted the mistake I made that rendered the inequality invalid for a greater than 1
Mathematics news on Phys.org
That's not the hypothesis used in induction.
Ordinary induction would use the hypothesis:
n!\geq a^n where we think of n as a particular integer, not as "all integers".
and you would have to prove (n+1)! \geq a^{n+1}
So-called "strong induction" would use the hypothesis:
For each integer i: 0 < i \leq n , i! \geq a^i
and you would still have to prove (n+1)! \geq a^{n+1}
I am sorry, I messed up with latex. That was not my hypothesis...
I was having trouble too. The world will probably end because of clerical errors.
The problem is that n+1 \geq a does not imply that n \geq a which you seem to have used.
The basic problem seems to be that allowed values of a increase with n, while induction would work only if a is constant.
