Prove limit of complex function
complexnumber
Prove that lim_{z -> 1 - i} [x + i(2x+y)] = 1 + i
where z = x + iy
Prove using definition of complex limit.
Start from |x + i(2x + y) - (1 + i)| < epsilon, need to transform LHS to an expression that includes |(x + iy) - (1 - i)|.
|x + i 2x + i y - 1 - i| < epsilon
|(x + iy) + i 2x - 1 - i| < epsilon
Eh, OK I am assuming you handle these kind of limits the same way you do in one-variable calculus. So basically we need to find bounds for |x-1| and |y+1|. Note
|x + i(2x + y) - (1 + i)| = |x + 2xi - 1 - i + iy| = |x + 2xi -1 - i + (-i) + i + iy| = |(x-1)(1+2i) + i i(y+1)|.
So yeah, you should be able to take it from here.
snipez90, thanks for your reply.
Continue from your RHS, I get
<br /> \begin{align*}<br /> |(x-1)(1+2i) + i (y + 1)| =&amp; \left|(1+2i) [(x-1) + \frac{i(y+1)}{1 +<br /> 2i}] \right| \\<br /> =&amp; |1+2i| \left| (x-1) + \frac{i(y+1) (1 - 2i)}{(1 + 2i) (1 - 2i)} \right| \\<br /> =&amp; |1+2i| \left| (x-1) + \frac{i(y+1) + 2(y+1)}{1 + 2i - 2i + 4}<br /> \right| \\<br /> =&amp; |1+2i| \left| (x-1) + \frac{i + 2}{5} (y+1) \right| \\<br /> =&amp; \sqrt{5} \left| (x-1) + \frac{i + 2}{5} (y+1) \right|<br /> \end{align*}<br />
However, this is still not the same as required expression consisting of |(x-1) + i(y+1)|. What should I do from here?
Hmm, what I was thinking was that you could apply the triangle inequality to
|(x-1)(1+2i) + i(y+1)| (sorry about typo above) so that
|(x-1)(1+2i) + i(y+1)| \le \sqrt{5}|x-1| + |y +1|.
Then require each of the two terms on the right to be less than \varepsilon/2, and then choose delta accordingly.
Thank you for your reply to both of my threads. I get the idea now; i didn't think of triangle inequality at all.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
