Prove that an improper fraction with a finite binary expansion
12 replies · 5K views · last reply
Jamin2112
I'm supposed to prove that an improper fraction with a finite binary expansion also can be written as a decimal.
Obviously my fraction a/b, where a>b, will look like p1/21 + p2/22 + ... + pn/2n
And I have no idea where to go with this.
Can you write [itex]\frac{1}{2^n}[/itex] as a decimal for any n? Maybe try to do it by hand and see if there's a pattern. Then maybe use induction to formally establish that pattern.
1/21 = 1/2 = .5
1/22 = 1/4 = .25
1/23 = 1/8 = .125
1/24 = 1/16 = .0625
1/25 = 1/32 = .03125
1/26 = 1/64 = .015625
Hmmmm ... No pattern detected. Hint?
Are you going to get any non-terminating or repeating decimals out of this? Why or why not?
Since the last digit is 5, and 5/2 is a decimal, you will always be able to get a decimal answer.
OK, so now you have a number with a finite binary representation (ie coefficients of negative powers of 2). And you have terminating decimals for each negative power of 2. Prove that you have won. :)
I'll take a shot at it.
Proof:
An improper fraction can be represented a/b, where a < b, and a, b [tex]\in[/tex] [tex]Z[/tex]. Suppose a/b can be represented as a finite binary expansion. Then a/b = m1/21 + m2/22 + m3/23 + ... + mn/2n.
Where should I go from here? Hence a/b = [tex]\delta[/tex]1/101 + [tex]\delta[/tex]2/102 + [tex]\delta[/tex]3/103 + ... + [tex]\delta[/tex]k/10k.
OK, so now you need the [itex]\delta_i[/itex] values.
So suppose I give you 1011.101 in binary. Can you convert it to decimal?
I presume you mean can be written as a finite decimal expansion- any number can be "written as a decimal". A number can be written as a finite binary expansion if and only if it is a fraction that, reduced to lowest form, has a power of 2 as denominator. A number can be written as a finite decimal expansion if and only if it is a fraction that, reduce to lowest form, has denominator which is a product of powers of 2 and 5 only.
Sure.
(1x23)+(0x22)+(1x21)+(1x20)+(1x2-1)+(0x2-2)+(1x2-3) = 8 + 0 + 2 + 1 + 1/2 + 0 + 1/8 = 11 5/8 = 11.625.
All that matters is how I went about making the (1/2 + 0 + 1/8) into a decimal, i.e., I need to show that 100/2, 100/4, 100/8, 100/16, ... are decimals. I suppose some sort of induction would be necessary. My statement P(n): for all integers n≥1, 100/2n is a rational number. Proof. We use induction on n. If n=1, then 100/2n=100/21, a rational number. Thus the base case holds. Now we wish to show that if 100/2n is a rational number, then 100/2n+1 is a rational number. 100/2n is converted to 100/2n+1 simply by dividing by 2. Because halving a rational yields another rational number, 100/2n is a rational number for all n.
Something like that?
I'm supposed to prove that an improper fraction that can be represented with a finite binary expansion can also be written as a decimal (a base 10 expansion, in other words), but not the converse (show that not all finite base 10 expansions have finite base 2 expansions)
So ...
1/21 = .5 -----
1/22 = .25 -----
1/23 = .125 ----- ends in 125
1/24 = .0625 ----- ends in 625
1/25 = .03125 ----- ends in 125
1/26 = .0015625 ----- ends in 625
1/27 = .00078125 ----- ends in 125
1/28 =.00390625 ----- ends in 625
1/29=.001953125 ----- ends in 125
That's the only patter I can detect: the last 3 digits alternate between 125 and 625.
As I said before, the numbers that can be written as a finite decimal expansion are those rational numbers which, reduced to lowest form, have denominators powers of 2 and 5. A number will have a finite binary expansion if and only if it can be written as a fraction with denominator a power of 2 only.
Obviously if [itex]x= \frac{m}{2^n}[/itex] then it can be written as [itex]x= \frac{m}{2^n5^0}[/itex]. 1/5= 0.2 has a finite decimal expansion but its denominator is not a power of 2 and so cannot be written as a finite binary expansion.
