Prove that any curve can be parameterized by arc length
To prove that any curve can be parameterized by arc length, the discussion emphasizes using the hint involving the integral of the speed of the parameterization. The key is defining h(s) as the integral of the speed of the original parameterization, which allows for the construction of a new parameterization, γ, through the inverse of h. Participants debate the correct application of the chain rule and the differentiation of inverse functions, highlighting the importance of accurately expressing the derivatives involved. The conversation reveals confusion around the relationship between the derivatives of the original and inverse functions, ultimately leading to a better understanding of how to derive the arc length parameterization. The thread concludes with a focus on clarifying these derivative relationships to successfully complete the proof.
stripes
Prove that any curve \Gamma can be parameterized by arc length.
Hint: If η is any parameterization (of \Gamma I am guessing), let h(s) = \int^{s}_{a} \left| \eta ' (t) \right| dt and consider \gamma = \eta \circ h^{-1}.
Given the hint, we have \gamma = \eta \circ h^{-1} (t) = (x(h^{-1} (t), y(h^{-1} (t)) and thus \left| \gamma ' (t) \right| = \sqrt{ [x' (h^{-1} (t))]^{2} + [y' (h^{-1} (t))]^{2}} but what good is this if I can't find the inverse of h(t)?
I know I have to show there exists a parameterization \gamma : [a, b] \rightarrow \Re^{2} of \Gamma so that \left| \gamma ' (t) \right| = 1 for all t. Perhaps this hint will reveal this parameterization, but I can't see how. Any help would be appreciated.
Your expression for ## |\gamma'(t)| ## is incorrect. Fix that, then apply the rule for differentiating inverse functions.
What exactly is wrong with my expression?
If gamma is a parameterization, then |γ'| = sqrt ( x'(t)^2 + y'(t)^2), is it not?
The equation is correct in #3, but not in #1.
But the parametrization is a function of h^-1 which is a function of t. Would I need to use chain rule?
Yes, you have to use the chain rule. Which you tried, but you either did not do it correctly, or did not write the result correctly.
Oh I forgot because h is a function of s, not t. All this time I thought it was a function of t. Alright I'm plugging away I will be back.
No, that was not the problem. The problem is that the chain rule should have resulted in a product of two derivatives.
So
\eta (t) = (x(t), y(t)) is any parametrization. Then let
h(s) = \int^{s}_{a} | \eta ' (t) | dt
Now consider
\gamma (t) = \eta (h^{-1} (s)) = (x(h^{-1} (s)), y(h^{-1} (s))).
We have
| \gamma ' (t) | = | \gamma ' (h^{-1} (s)) | = \sqrt{(x'(h^{-1} (s))([h^{-1}]' (s))^{2} + (y'(h^{-1} (s))([h^{-1}]' (s))^{2}}
= ... = |\eta ' (s) | \sqrt{ x'(h^{-1} (s))^{2} + y'(h^{-1} (s))^{2}}
but now what?
That is not correct. ## (h^{-1})' \ne |\eta'| ##.
Well we defined h(s) = \int^{s}_{a} | \eta ' (t) |dt didn't we? So by the FTC we end up with | \eta ' (t) | or | \eta ' (s) |?
Chain rule is really irritating me right now...
Yes, ## h' ## is indeed equal to ## |\eta'| ##. But you have ## h^{-1} ## to differentiate.
Right. So it'd be |n'|', but that still doesn't seem useful.
Furthermore, how am I going to deal with the square root stuff?
Why would that be so? Say you have y = f(x), and you also have its inverse x = g(y): g(f(x)) = x. Is there an equation linking f' and g'?
I think that's enough for me today. I'll hand in wha I've got. Thanks for your help!
  • · Replies 43 ·
