Prove that f is a constant function
The discussion revolves around proving that the function f, defined from R to R, is constant under the condition that the inequality involving a summation of differences of f is bounded by 1 for all positive integers n and real numbers x and y. Participants explore various methods, including differentiation and the Mean Value Theorem, to analyze the behavior of f. They establish that the differences f(a) - f(-a) can be bounded and show that these bounds tighten as n increases, suggesting that the differences approach zero. Ultimately, the argument leads to the conclusion that f must be constant as the bounds on the differences diminish with increasing n. The conversation emphasizes the importance of careful handling of inequalities and the implications of the given conditions.
AdityaDev
Suppose that f:R->R satisfies the inequality ##|\sum\limits_{k=1}^n3^k[f(x+ky)-f(x-ky)]|<=1## for every positive integer k, for all real x, y. Prove that f is a constant function.
None
I tried taking f(x)=sinx and then using sinC-sinD=2cos(C/2+D/2)sin(C/2-D/2). Then you will get 2cosx.sinky. |cosx| is always less than or equal to one, but greater than zero. So I ignored cosx from the sum since it is just like a positive constant. and you will be left with
$$2\sum3^ksinky=2.Im\sum3^ke^{iky}$$
I am not sure about this procedure. Is there a general method?
None
To prove a function is constant you often prove that the derivative is zero.
There are 2 variables x and y. Should I differentiate the expression with respect to x or with respect to y?
As far as f is concerned, it is a function of a single variable.
If I differentiate w.r.t t, then you will have $$\sum\limits_{k=1}^n3^k[f'(x+ky). (\frac{dx}{dt}+k\frac{dy}{dt})-f'(x-ky). (\frac{dx}{dt}-k\frac{dy}{dt})]$$
I didn't mean to imply endorsement of differentiating. Since Dick suggested it, I'm prepared to believe that helps, but I don't see it yet.
I think there's something not quite right in the OP. Should it say "for every positive integer n, for all real x, y"?
It does.
I thinks its just <sum expression> for all real x, y.
But n is also a variable for that sum, and the terms inside the sum can change sign as k changes, so I think it's important to include "for all n".
Likes AdityaDev
Don't differentiate with respect to either one. Remember that the derivative is the limit of a difference quotient. Let y approach zero and take the limit.
Likes AdityaDev
Actually letting y actually approach zero doesn't cut it. I think you need some sort of mean value theorem type of thing to get the difference to actually equal ##f'(c) 2ky## for some value of ##c## and nonzero ##y##. Or you need to make some sort of approximation argument about the difference in terms a derivative. THEN you can let ##k## approach infinity to conclude ##f'(c)=0##. Maybe I haven't thought this through enough, so you try and fill in the details for me.
Fix on some x to begin with. For simplicity I'll take x=0.
Consider f(a)-f(-a). By suitable choices of n and y, what bounds can you put on it?
Next, consider n=2, but changing y such that the extreme ends of the sum are still at -a and +a, you should now be able to put tighter bounds on that difference. And so on.
Likes AdityaDev
For x=0, then you get f(a) for n=1, y=a.
For n=2, the expression has two pairs: f(y)-f(-y) + f(2y)-f(-2y)
then there is no value of y for which y=a and -2y=-a.
According to MVT, $$f'(c)=\frac{f(x+ky)-f(x-ky)}{2ky}$$
Hence ##f'(c)2ky=g(k)## where g(k)=f(x+ky)-f(x-ky)
If I take a point x, f(x) on the curve Y=f(X), then the two points x-ky and x+ky on the X-axis are aymmetrically placed about X=x. So can I say that the arbitary point c will remain same for any value of k? That is, can I say that the lines formed by connecting (x-2y,f(x-2y)) and (x+2y, f(x+2y)) will be parallel to that formed by (x-y, f(x-y)) and (x+y,f(x+y))?
Good point, and no you can't say that. So this won't work in the way I was thinking.
Yes, but what inequality do you get for |f(a)-f(-a)|?
Sorry, a small error in what I posted may have misled you:
I meant the extreme top end of the sum, singular. I.e. a = ny. What inequality do you get now? How can you combine this with the n=1 inequality to get even tighter bounds on f(a)-f(-a)?
Likes AdityaDev
For n=1, y=a, the inequality will be |f(a)-f(-a)|<=1. So f(a)-f(-a) is greater than -1 and less than 1.
for n=2,y=a, you get f(a)-f(-a)+f(2a)-f(-2a) and this should again lie between -1 and 1. Let f(a)-f(-a)=A. So---> -1-A<=f(2a)-f(-2a)<=1-A.
No, the given inequality has 3k, not 3k-1, and this is the k=n term.
I meant you to pick y such that the k=n (=2) term corresponds to f(a), but I don't think it matters.
What does matter is that you've left out the power-of-three factors again.
Sorry.
For n=2, y can be taken as a/2
So 3[f(a/2)-f(-a/2)] + 9[f(a)-f(-a)]
And ##-1/3\le f(a)-f(-a) \le 1/3##
AdityaDev said:
Sorry.
Right, but properly: |3[f(a/2)-f(-a/2)] + 9[f(a)-f(-a)]|≤1
Now, in ##-1/3\le f(a)-f(-a) \le 1/3##, a was arbitrary, so it applies equally to a/2, right?
How can you use that to eliminate the f(a/2) terms from the n=2 inequality?
Likes AdityaDev
Yes. It applies to a/2.
$$-1/3\le f(a)-f(-a)\le 1/3$$
$$-3\le 9f(a)-9f(-a)\le 3$$
And,
$$-1/3\le f(a/2)-f(-a/2)\le 1/3$$
$$-1\le 3f(a/2)-3f(-a/2)\le 1$$
adding them, ##-4\le A+B\le 4##
And,
You have to be careful with the modulus signs here.
If |x+y|<|z|, what bound can you put on |x| in terms of y and z?
Likes AdityaDev
-z<x+y<z
-z-y<x<z-y
So |-z-y|<|x|<|z-y|
AdityaDev said:
-z<x+y<z
-z-y<x<z-y
So |-z-y|<|x|<|z-y|
No, the last step is not valid. E.g. x=1, y=2, z=4 satisfies the original inequality, as does x=-2, y=3, z=4.
Likes AdityaDev
For x+y>0 and z>0, x<z-y
for x+y> 0,z<0 then x<-z-y
For x+y<0, z<0 then x>z-y
for x+y<0,z> 0 then x>-z-y
You need to get it into the form |x|< some function of y and z. I'll give you a lead, it will be a function of |y| and |z|. A quite simple one.
For example, |x-2|>|4|
Then x can be -1,0,1,2,3,4,5
So x<|y|+|z| and greater than |y|-|z|
I'll settle for |x|<|y|+|z|.
Now to resume the main discusion. You found |f(a/2)-f(-a/2)| <1/3. Now write out the inequality for the case n=2, ny=a. Use the |x+y|<|z| implies |x|<|y|+|z| result to rearrange it into the form |f(a)-f(-a)|< ... form.
Likes AdityaDev
so for n=2,y=a/2,
$$|f(a/2)-f(a/2)+f(a)-f(-a)|\le 1/9$$
So $$|f(a)-f(-a)|\le|f(a/2)-f(-a/2)|+1/9$$
and $$|f(a/2)-f(-a/2)|\le 1/3$$
so $$|f(a)-f(-a)|\le 1/3+1/9$$
  • · Replies 18 ·
