How can we mathematically differentiate between a straight line and a curve?
  • Thread starter Thread starter Momi
    Curve Line
To differentiate between a straight line and a curve mathematically, it's essential to define both terms clearly. A straight line is characterized by a constant slope, while a curve has a variable slope that changes direction. The distinction can be formalized using calculus, where a straight line has a constant derivative, and a curve has a derivative that varies. Understanding these definitions is crucial for proving the differences between the two. Clear mathematical language and definitions are necessary for precise discussions on this topic.
Momi
How to prove line is a curve?
I only know that line is a straight curve but how it can be proved?no idea!
Immediate help would be appreciated...:smile:
regards,
Momi
Can you provide more context of the question and your "definitions" of "line" and "curve"?
Otherwise, the discussion isn't going to very precise... and you won't end up with a proof.
O didn't know that u could call a line for a curve, even a line segment would be a curve so it don't need to be continuous ..
http://en.wikipedia.org/wiki/Curve
I'm sure what you mean is that a curve and a straight line are different to you because, well, a straight line goes straight and a curve line changes directions. Put this into mathematical language!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
